Hep with Margins, on AT&T Modell #6200 typewriter. Right margin will not work. Need instruction manual.
Geno111
  • 183 Answers
SOURCE: cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Posted on Oct 24, 2008
Geno111
  • 183 Answers
SOURCE: Setting Margins
move the carrier to where you want the mar.set then hit the R MAR or L MAR key.
to move the carrier beyond the margins hit the MAR REL key
Posted on Nov 25, 2008
  • 125 Answers
SOURCE: Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Posted on Mar 19, 2009
  • 46 Answers
SOURCE: resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Posted on Jun 26, 2009
  • 11 Answers
SOURCE: Need help releasing margins on an electronic typewriter.
Did you hit the MAR and REL buttons at the same time?
Posted on Sep 04, 2009
How do I set or change the margins on my Royal Safari typewriter?
If you are following user's manual instructions to reset the margin and can't, maybe your Royal Safari is defective? Insist trying and if still no luck try to ge a typwriter repairman, a species in near extintion by now.
Jul 02, 2015 | Royal Office Equipment & Supplies
Cannot release my margins on my 6200 portable at@t electronic typewriter. do not have a user manual.
Generally speaking go to the margin you want to reset touch don't hold the mar rel key space or backspace to desired location, press L. or R. margin key.
DickyO
Sep 07, 2011 | Office Equipment & Supplies
Unable to move past left & right margins to reset
Go to broyher.com, click on support you will find a manual there.
DickyO
May 20, 2010 | Brother ML-300 Typewriter
I do not have a manual for the IBM wheelwriter 3, but I need to know how to set margins for this typewriter. Each time I press return the left margin changes moves to the right. If I shut it off the margin...
The WW3 resets margins and tabs to default on every power up. If the margins change while you are typing then the silver shaft that nthe carrier slides on is probably gummy. A shot of WD40 on both sies of the shaft shouls free it up.
Go to lexmark.com, click on support you will find a downloadable manual there.
DickyO
May 18, 2010 | IBM Wheelwriter 30 Typewriter
How do I type to the end
To reset the margins you need to first release the margins. Once you have released the margins you will be able to set the left and right hand margins.
Thanks,
Pat
May 12, 2010 | Brother GX-6750 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
Have no manual How do you set the margins on the compact S model
The Startype 3 is the same machine as the Nakajima AE-740.
Go to www.nadist.com and download the Nakajima manual for FREE.
Jul 28, 2009 | Olympia Startype 3 Typewriter
Resetting the margins on a manual typewriter.
Feb 19, 2009 | Royal MS 25 Typewriter
Jan 31, 2009 | Office Equipment & Supplies
63 people viewed this question
k24674
jasbo
jasbo
