Question about Thomson X3030E (30 GB) Digital Media Player
My Thomson x3030e will not boot. There is only black screen
Did you sort out this problem? I just brought one and it's not working either. I've got all the system requirements it says I need and have tried to charge it for 5 hours (it says at least 3) and it won't do anything.
Posted on May 18, 2011
Tv thomson black screen
this a problem from Raster, coming from HV flyback, rectifiier, horizontal output, and circuit from HV. repair.or go to the repair shop TV for fix it.
However you must reset the code, download from www.fitness.manualsonline. com or memorex.com or www. remotecodelist.com and try it again.
God bless you
Jul 22, 2012 | Thomson RCT311DA1 Remote Control
I can't open my thomson gateway
What's the error message?Have you tried to go to the exact modem page?
1. open internet explorer2. type the numbers 192.168.1.254 on the address bar then press enter3. you will be routed to thomson page settings if you received any message stating error like can not display page then you need to check if the cables are properly connected.4. if still can not connect, go to the start menu icon5. select the run icon or search bar6. type cmd then press enter7. you should received a black screen8. from the black screen type ipconfig then press enter9. you should received the info like IP ADDRESS, SUBNET MASK and DEFAULT GATEWAY.10. copy the default gateway and type it in the address bar of your internet explorer then press enter11. if you have not received these information (ip address, subnet mask and default gateway) on the black screen after typing the ipconfig then check the error "media state disconnected" which means that your pc and your thompson is not communicating, here you need to try different network cable to isolate issues for the problem might be the cable, network cable port at the back of your pc or the network cable port at the back of the thomson.
kindly rate rate this post, thanks
Dec 31, 2011 | Computers & Internet
The screen is blue
go to the main menu and turn the color all the way off and see if you have perfect black and white or if it has a blue tint, might be able to adjust down blue g2 screen
May 05, 2010 | Thomson Televison & Video
Black screen
Hi there! May be Inverter board. Check for loose solder joints or cables. If all OK and still the same issue then this board will have to be replaced if 24v is present at inverter side. Best Wishes and Good Luck, JUS004
Aug 31, 2009 | Televison & Video
HI, TV Thomson Black DIVA
how to known the service mode for thomson tv blackdiva
Jan 15, 2008 | LG DR-4810 DVD Recorder
TV LCD THomson 26"
If what your saying is that there are vertical stripes down the screen, You have a screen drive problem my friend. This could mean you will need to change the entire main board, the screen driver board if it is separate on this set, or the main LCD panel itself. These boards do not have any parts available for them and must be replace as a whole unit. Good Luck
Mar 19, 2007 | Thomson 20LCDB03B 20 in. Television
Open Questions:
Thomson X3030E (30 GB) Digital Media Player Logo
127 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
