Question about Toshiba Satellite Pro L300 Notebook
Toshiba satellite L300 black screen. Tried the 0 key and it only goes 1/3. thinking booing/registry corrupt. No recovery disk or software came with my laptop. O/S is Vista I have data and photos that I don't want to loose, if I tried a recovery disk will I loose my data
    Scholar:
  • 115 Answers
Yes everything will be wiped out, once you do the recovery. It will reinstall the factory settings.
You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, then try to boot from safemode. Tap F8 upon booting up to enter the advance boot option. Select safe mode, save your files once loaded in safe mode. You may first try the system restore from , go to start/all programs/accessories/system tools/system restore, select the previous date the laptop was working fine. If this will not work then the last resolution is the recovery.
Hope this helps.
Posted on Mar 23, 2011
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
Whenever I try to start my Toshiba Satellite Laptop the Toshiba logo comes on but then the screen goes blank and all there is is a blinking underscore in the upper corner of the screen; I already set
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
How can I factory reset my Toshiba Satellite laptop without a disc?
your notebook.
Feb 14, 2012 | Toshiba Satellite 2405-S201 Notebook
Cant restore to factory settings tried 0,f1 and f8 none work
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Aug 16, 2011 | Toshiba Satellite Pro L300 Notebook
Have tried to completely restore laptop by running dvd recovery disks. Inserted disk 1 ,after a while got message "bootmgr missing" Any ideas?
There are corrupted files from the recovery disc which the computer cannot read. Use another recovery disc.
Hope this helps.
Jun 12, 2011 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba Satellite Pro L300 With Windows Vista on it. Keep getting BOOTMGR during startup. I'm not in the possession of a vista dvd. Seeing this laptop came with the OS...
your notebook.
May 30, 2011 | Toshiba Satellite Pro L300 Notebook
How to mater reset
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
Mar 04, 2011 | Toshiba Satellite Pro L300 Notebook
Hi i have a toshiba satellite l300 and ive tried alt f10, f8, f5 and tapping the 0 key but nothing happens can someone help me with this!
tapping the f8 key is done when the toshiba screen first lights up on the screen when you turn on this computer
Sep 19, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba media recovery satellite l300 series windows vista home premium disk doesn't work it gets stuck on a black screen with a mouse cursor
Try cleaning the disk in soap and water / dry with a microfiber cloth or cotton towel . Then try your disk. If you don't get the proper response then I suspect a corrupt data disk or a malfunctioning DVD.
May 09, 2010 | Toshiba Satellite L305-S5907 Laptop
I need to reboot w/o disc Toshiba Satellite L300
You can restore the system to Factory condition (out-of-box state) by doing the following:
1) Press the power button till the machine goes off
2) Now hold the 0 (zero) key and tap the power button once to switch on the system
3) When you hear the machine beep release the 0 button.
4) On warning screen select Yes for system recovery.
5) Select Recovery of Factory Default Software and hit Next
You should be able to restore the computer to out-of-box state.
Please feel free to get back for any further assistance.
If you find this solution helpful, please do not forget to rate and leave your comments.
Thank you for choosing Fixya.
Mar 23, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
552 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
