Hi I have a Beko NR 32WLJ520HD TV and it is giving me trouble recently. Usually when I turn it on it goes into standby and if I push any channel number on the remote or Program UP/DOWN on the side of the TV it brings up the channel I was last on before turning it off. Now when I turn it on it's constantly stuck in Standby and no matter what I do I can't get a picture. I have tried removing all plugs and making sure they're put back in properly and I've tried every button the TV and Remote have but nothing will make it come off Standby. The TV itself is only 3 years old and it says nothing about this in the troubleshooting section of the manual. I would love if you could help me!
ladywinn
  • 5138 Answers
SOURCE: plasma ps42p2sb stuck on standby
Your set needs to go in for repair this is no easy fix it yourself problem!
Posted on Feb 08, 2008
SOURCE: can't turn on tv
Unplug the tv for 30 and plug back in.
Posted on May 31, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
SOURCE: Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Posted on Nov 06, 2008
  • 55 Answers
SOURCE: My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Posted on Oct 06, 2009
Hi y Beko tv is 7 years old. Suddenly the picture keeps flashing and wont stop. There is sound but picture is constantly flashing. I cleaned any dust off. The model is. 32WLJ520HD.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Feb 17, 2015 | Beko Televison & Video
Beko nr 15lb450s no sound
audio chep most be replaced or try to diag. from speaker wire test it with the tester if given power. if not try to check all capasito and resitor if given the right voltage.
Jul 01, 2012 | Beko Televison & Video
My 32in beko tv keeps blinking and will not stop. The sound And picture is still good the screen Just goes black every other second Model nr 32WLZ530HID Service info Ix-Id tv...
It sounds like the backlight inverter circuit has developed a fault. This can usually be cured by changing some transistors and capacitors, or it could be a poor solder joint.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Beko Televison & Video
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Sky codes for beko 32' tv
on the sky remote press the following
TV
RED + SELECT (blinks twice)
TV
0125
press the volume button,if it works press SELECT if not press TV then VOLUME again repeat this process of TV then VOLUME until it works then press the SELECT button to save the code to your remote.
Enjoy
Littlle Dish Fitter
Dec 27, 2008 | Beko 324250WN 28" TV
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
Don't work my t.v Beko model NR 21T75NXM
power ok.after 5min on .up and down pictuer dark.
Jan 19, 2008 | Beko 324250WN 28" TV
Wont come on
try pressing one of the number keys instead of the power button on the remote
Sep 06, 2007 | Beko 324250WN 28" TV
Auto off
make checks in the standby power supply and related tey could be deffected if not make checks on eeprom and the microchip.good luck.
Jan 22, 2007 | Sanyo DS20930 20" TV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
