FixYa.com
Tags:
Sony Net MD Walkman MZ-N707 Personal MiniDisc Player
Problem with Sony MZ-N707
By Jimmy NY - usenet poster
This this maddening!  When I record to disk it seems like all is well, but
it won't play.  There is no sound at all and when I eject and re-install the
disc, the "Blank Disk" flashes.  I have tried this with several disks and
always the same.  Also, I have tried the newer SonicStage, Real One player
and the Simple Burner.  I think this thing is toast.
Any suggestions from this group?
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 11, 2005
Thanks for Trying (70)
Putty
Putty - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In addition to what the other folks say about usb transfers: There is a
possible hardware issue here as well
I have had this happen on a few occasions over the last decade.  Since
I'm using older (pre-NET) Md's, I am always using either LINE, Optical
or Mic inputs.  (A mixture depending on the job).
IN all cases the recorder showed normal record.... but the disk came out
and went back in blank.
Sometimes this was due to errors (mine) at the "Shutdown" point,,,
Example.  I dropped the recorder, just hard enough to trigger the "Open
door" switch, and re-set the disk, the TOC was never written to disk and
  thus, though the recording was there, I could not access it (This is
easily,... well not all that easily,,, fixed however)
In other cases I had a record-overwrite head failure.  Mini discs are
"Magneto optical" this means that a laser is used to heat up a tiny spot
equivalent to one bit to the point where a magnetic record head, just
like a cassette or DAT recorder's head, can "Flip" it one to zero or the
other way around.  Then a laser (at lower power) is used to read the
bits.  The magnetic head is called the "Record overwrite head" and rides
on top of the disc (lasers go down below)  In one case I found that I'd
jammed in a disk wrong, caught the edge of the (I'm going to say just
record here) record head and folded it back upon itself,,, Did not work
that way.  In another the lever that lowers the head had gotten out of
place, in yet another one of the support wires had broken... They are
also the "Working" wires (Carry current) so that did not work well, IN
two cases I was able to fix, in two I was not  I do not suggest
attempting self-repair unless it is a very old unit (one was an R-2) and
you feel you have "Nothing to loose" cause I could have turned that R-2
into an E-2 (play only) real easy messing with that head.
So, it is possible it's a hardware problem
So, the suggestion depends on the warranty status....
If it's under warranty... That's the suggestion
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
Yes, this with the usb transfer and all other usb devices are working.  I do
not have a microphone to test the other methods so will borrow one and see.
I only use the usb import for my music however.  The write protection is in
the proper place as well.
After the transfer I have tried several methods suggested.  Each time there
is nothing on the disk.  If I hit play right after the transfer, the song is
displayed with the timing but there is no sound at all.  When the disk is
ejected and reinserted "Blank Disk" flashes.
I will try a line in recording and try that.  Thanks for the advice.
Solution #3
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
Sounds like you're trying a USB transfer.  Since this doesn't seem to work
even with SimpleBurner, I'm wondering if you're doing anything wrong.  Are
you using the AC adapter with the MD?  Is the MD's write protect OFF (i.e.
covering up the hole)?
When the transfer is complete, what do you do?  I typically shut down the
program on the PC, then pull the USB cable.  The TOC edit seems to happen
after the USB cable is pulled.  Make sure power to the NetMD isn't
interrupted during this process.  Only after the MD display goes blank do I
pull the AC adapter cable out of the NetMD.
If this model has a line/digital input (like mine), try recording from that
just to see if the unit will record at all.  If this works, maybe you have
some sort of weird problem with USB, your PC, your OS, or your software on
your PC.  Do other USB devices work well on your PC?
Jeff
Remove icky phrase from email address to get a valid address.
Can you Help with these Personal Audio Mini Disc Player problems?
iluv
i have an ILuv 4 disc player... Answer This...
stereo system problem
i have a jvc compact component... Answer This...
Starting up and Charging
I have an Audiophase... Answer This...
mini disc player technics...
hi there i noticed your... Answer This...
Sony 3 cd Player.After a power...
This Hi Fi is approx. 4 years... Answer This...
Repair Service
Find Personal Audio Min. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
