Question about ASUS P4P800-VM Motherboard
In 2.1 the sound is missing. in 5.1 i have signal on the pink and blue. is the channel green "out"?
    Sergeant:
  • 113 Answers
Yes green color is the out for sound
Posted on Sep 28, 2011
Looking for wiring diagram for door locks on a 2005 f250
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES 12 VOLTS Yellow Ignition harness IGNITION RED / green Ignition harness IGNITION 2 Blue/green This wire is only required on the V-10 Gas engine. ACCESSORY RED / black Ignition harness ACCESSORY 2 Gray / YELLOW Ignition harness STARTER Dk.green Ignition harness KEY SENSE BLACK/ pink In airbag plug on right side of st. column TACH SIGNAL Use an injector DIESEL TACH SIGNAL GREEN / WHITE SEE NOTES Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the GREEN / WHITE among these wires. LOCK WHITE/ red In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. UNLOCK BLACK/ white In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. DRIVER LOCK MOTOR Pink/black In harness above gas pedal DRIVER UNLOCK MOTOR RED / orange In harness above gas pedal PASSENGER UNLOCK MOTOR Pink/orange In harness above gas pedal GLO-PLUG SIGNAL DATA ONLY USE DELAY TIMER DOORPIN BLACK/ blue Above parking brake in DKP The vehicle's computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions. FACTORY ARM Yellow/black Above parking brake in DKP This is the driver's doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm. FACTORY DISARM Dk.GREEN/ purple In harness above gas pedal BRAKESWITCH Green At switch above brake pedal PARKLIGHTS Brown At light switch harness HAND BRAKE Lt.GREEN/ red At plug above handbrake lever HORN Dk.blue In airbag plug on right side of st. column
Dec 25, 2017 | Cars & Trucks
I need to know what wires i am lookin for to install new speakers
This should help.
1989-91 Ford Thunderbird Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
Aug 20, 2011 | 1990 Ford Thunderbird
I got a new motherboard, and the back only has a pink, green, and blue color for the jacks. However, these logitech speakers have a green, pink, orange, and black. i have the green and pink in and my...
PINK -- if you have a microphone, connect it here
GREEN -- if you have a headset, or you have external speakers, connect it here,
to get 2-channel stereo output ("left" and "right").
BLUE -- if you have an iPod (or iPod Touch), or audio-cassette player, and you want to feed the "audio-output" from those devices into a program that will record the sound on the "line-input" port on your computer, then you need to connect this port.
Since your new motherboard does not support 5.1 audio-output, you need to purchase a sound-card that has GREEN and PINK and ORANGE and BLACK sockets, so that you can get sound into the "middle" and "back-left" and "back-right" speakers.
Or, just connect the GREEN, to use your speakers in two-channel mode.
You'll also need to access the web-site for the manufacturer of the motherboard, to download the correct device-drivers for the audio-hardware embedded onto the new motherboard, in order to get _ANY_ output out of your sound-card.
Feb 17, 2011 | Logitech G51 5.1 Multimedia Surround Sound...
I need a radio wiring diagram
Constant 12V+ Green/Purple
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
best wishes
Jan 01, 2011 | 1992 Ford Explorer
Dlp picture showing pink and green
Hello sir, good day, your dlp is missing the B (blue) color from the RGB signal, this is caused by the Blue wire open, replace your dlp signal cable.
May 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How can i connect speaker on my computer
You need to find powered speakers that have an aux out so you can just plug it into your headphone jack,
Nov 08, 2009 | Audio Players & Recorders
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Color missing
You cannot fix this yourself. It is a problem in the signal path of the missing colour channel. The fault can be in the main processing, or along the video signal path, or in the actual panel. The signal processing is in digital. To track the signal processing path, would require the in depth design information, extensive instrumentation compared to what the standard service shop would have, and the data protocol information.
This type of set is serviced with module swapping. There is very little supported component level servicing on these sets. They use high density surface mount technology with multi layered circuit boards.
You will have to send the set out for factory level service.
Jerry G..
Apr 16, 2008 | iLO 3200 32 in. LCD Television
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
ASUS P4P800-VM Motherboard Logo
16 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
