Question about Filter Queen Majestic Canister Vacuum
Does not pick any thing up - Filter Queen Majestic Canister Vacuum
  • 2,510 Answers
Check the filter and the hoses for blockages and clogging. If you can, **** backwards through the pipes to dislodge any foreign stuff stuck in them. See it there is suction when the hoses are removed, this will tell you if the hose is blocked. Also check the attachments you are using in case they are blocked. Using a vacuum that is not sucking means that there is no cooling air going over the motor and it will overheat.
Posted on Mar 22, 2011
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Tip
Vac's that just stop
meany time's i find high priced vac's out by the road,4 the trash man to pickup. each time i c that i stop & pick it up.
about 90%of the vac's just need 1or2 thing to work.
i have never seen ny brand vac that didnt come with a red reset butten.
that seams to do it,but being i just picked it up i cheack 3 things.
the belt &i unstop no matter what.
belt reset switch &clean the dirt out. that allways helps.
but some times i c dead 1s.
thanks
life's handy man
on Mar 04, 2010 | Vacuums
Its not picking up good
well..make sure the belt is on correctly..make sure u empty dirt..carefully tryto see if it is clogged..maybe a hanger..carefully
Dec 10, 2012 | Bissell 3102-0 EasyVac Upright Vacuum
The vacuum is not picking up at all
if it is not picking things up -- then there is a blockage in the suction hose and /or a clogged filter.
clean and clear the unit and all should be working good as new.
c...
Feb 24, 2011 | Hoover Tempo Widepath Upright Vacuum -...
The vacum is 7 months old andAll of a sudden is very hard to push and it has lost suction how do I fix this
sounds like you have picked up some thing in the inlet pipe have a good look in the pick up brushes there may be thred stuck in there on the rollers
Oct 26, 2009 | Dirt Devil Featherlite Bagless Vacuum...
It suddenly doesn't pick things up. I can use the
Small length of reinforced plastic hose (about 5 inches) viewed from the bottom may be ruptured, you may also need to replace a worn brush assembly. They seem to fail both at the same time, I have just replaced them on my DC 07.
Oct 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Looud noise and no suction
the motor impella is blocked. you have to access this from the bottom
Jan 23, 2009 | Kenmore 34720 Upright Vacuum
Not picking up at all...burning smell..belt seems fine.
its one of 2 things, either your hose is blocked or you need a new belt,they do stretch over time. possibly the brushbar needs replacing too.
Iain
Dec 23, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Filter Queen Majestic Canister Vacuum Logo
Top Filter Queen Vacuums Experts
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
