Question about Kohler 1014-H2-96 Portrait 5' Whirlpool Bath Tub Finish: Biscuit
Is there some type of cover i can buy for my jacuzzi tub in my house when it is not in use
    Problem Solver:
  • 17 Answers
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Is it possible to buy somewhere the Optional "U-Frame Skirt" for a "Jacuzzi CIVA Whirlpool" bath tub? Anyone know where or other suggestions on covering the front?
Home Deport and Lowes each used to carry a generic front skirt for "jacuzzi" type tubs. You may find something at one of their stores that will work.
The other solution would be to contact a Jacuzzi Showroom for authorized replacement parts.
Dec 02, 2014 | Jacuzzi Home
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
Model identification
While the brand of the tub may be of importance to you it may not be important when finding parts for it.
Bath tub manufacturers do not make anything that goes into their tubs i,e. the jets, pumps and controls are all purchased from various Mfg.
Are you have any particular problems with either unit that would make you need the brand of either?
Rod
U S Parts Center
Jan 05, 2014 | Jacuzzi Home
Can not turn jacuzzi on or off
What type of jacuzzi tub are we talking about? indoor bathtub or outdoor hot tub?
Rod
US Parts Center
888-521-6183
Jul 04, 2012 | Jacuzzi Pool & Spa
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi doesn't work...no voltage to outlet, checked braker box, reset it..still not working...any ideas?
Maybe a GFCI outlet that it's pluged into may be tripped . check any other GFCI outlets through your house and make sure none are tripped.
Some tubs have access doors with GFCI outlets near motor at tub may be tripped.
May 12, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Recently purchaced a house with jacuzzi tub. Filled tub with water and pushed on button. nothing happened. There is power to outlet.
Two things come to mind; First check to see if there is a GFCI on the box or the power cord and be sure it is not tripped. Also be sure that the covers are all as their are quite often magnet switches on the doors that will kill all the power if the doors are open. Good luck.
Apr 01, 2010 | Garden
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Kohler 1014-H2-96 Portrait 5' Whirlpool Bath Tub Finish: Biscuit Logo
101 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
