Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Will not power on. I have checked the wall plug by switching the DTV box and the TV still no power or power light
  • 3 Answers
Have u seen the fuse in your basement or where it is?
is there power from your socket outlet
Posted on Sep 18, 2011
Direct tv reciever keeps flashing when plugged in.
Probably a power supply problem. Have you tried switching off at the mains for a few minutes?
Mar 25, 2014 | Directv D11 DTV Receiver
Motorola dct 6412 wont turn off
pull the power at the back of the box or the wall, which ever is more convient. then wait for all the power to bleed out of the capacitors takes a minute or two (we call this a power cycle) hopefully it comes back up. might be time to put it to pasture.
Oct 10, 2012 | Arris DCT6200 DTV Receiver
No sound output need sound unit
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 14, 2011 | Mintek DTV-233 23 in. TV/DVD Combo
Light in the set box is not changing red light is flickering. Green light is not coming inspite of changing the batteries in the remote control. I am having Dish TV in my house.
Hi, this is Mary with Dish Network Customer Service. It sounds like you are experiencing a power issue with your Dish network VIP622 DVR. You can try resetting the Receiver box by unplugging it for 10 seconds (if it is plugged into a surge protector, for the purpose of troubleshooting, plug directly into a wall outlet). Wait for receiver to reacquire satellite signal. If you are still having an issue, you will need to contact Dish Network because the receiver box will probably need to be replaced. I hope this information helps you.
Sep 03, 2010 | DISH Network ViP622 DVR DTV Receiver /...
DVR won't turn on. TV screen is black
This can be a variety of different things, ensure television is powered on, what color light do you see on the front of your DISH Network 311 receiver? The green light is the one you should be seeing if the receiver is in fact powered on. If the light is not on even after pressing the power button on both the remote & the receiver, then I would recommend checking the source from which the receiver is plugged in, is it plugged directly into a electrical outlet on your wall, or is it plugged into a power strip? If wall outlet, perhaps try a different outlet and see if that makes a difference, if it's plugged into a power strip or surge protector unplug from wall and unplug receiver from strip for 30 seconds and reconnect checking to see if issue has been resolved. While checking these things, I would also recommend double checking to ensure nothing may have become disconnected and that all cables are connected from the back of your receiver to the back of your tv and to the wall and they are hand tight. I hope this helps, if the issue is still not resolved please feel free to contact me directly or you can call our technical support team for further assistance @ 1-800-333-3474. My direct e-mail is Kirstie.Filosa@dishnetwork.com.
-Kirstie DISH Network
May 14, 2010 | DISH Network 311 DTV Receiver
Goodmans LD3265D1 TV won't switch on.
use a freeview box, turn the dtv off in the menu
To get it too power on press the source button a lot after a (good) few trys your get it up on another source, my own tv does this and using a freeview/freesat box makes it use-able just a pain to turn on in the first place even if you turn the dtv off in the menu
If anyone knows how to get it to turn on stright to another source would be great to know how
Mar 31, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Vip211 will not power up, no green light or signal?
Hi johnmcmillan with thereceiver not powering up we can try a few things to get the power on. Firstthing you will want to do is make sure the receiver is plugged directly intothe wall. If the receiver is plugged into the wall and the green light is noton you can do a reset by unplugging the power cord from the receiver for 10seconds and plug it back in. I will leave a link to help with this. http://www.dishnetwork.com/SupportSection/receiver-no-power
Oct 17, 2009 | DISH Network ViP 211 DTV Receiver
The receiver doesn´t work. When i switch on,
the solution: Fount of energy broken and 50€ less in the pocket...lolo
Aug 14, 2009 | Philips E-Box FTR9965 DTV Receiver
After the DTV switch, should I be placing the cable cord into the dtv output to receive all the DTV channels? Protron PLTV 3250 is the set I have and it doesn't seem to get the DTV channels like my other...
Your question is confusing. If you have cable, you don't need a DTV converter box.
If your cable company has switched to digital cable, they will provide you a box, and the cable should go from the wall into the box, then into your TV.
If you don't have cable but instead rely on an antenna, then the wire will go from the antenna into the DTV box, then from the DTV box into the back of the TV. If you're using a regular coaxial cable to go from the DTV box into the television, the TV should be set to channel 3. If you're using the red-yellow-white RCA wires between the DTV box and the television, the TV must be tuned to "Aux," "Line In," "Input Select," or whatever it's labeled on your particular set.
Jun 12, 2009 | Protron PLTV-3750 Television
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
