Question about Samsung RS2630WW Side by Side Refrigerator
The interior fridge lights will not come on, but it is cooling just fine. I have unplugged the fridge to let it "reset" but it did not help.
    President:
  • 2,468 Answers
The door switch is bad you can pull it out of the door perimeter and bypass it to test its operation,sometimes these switches get sticky from food/juice,etc and stick part way open and you can spray wd40 into the plunger and unstick them,sometimes,not always
Posted on Mar 22, 2011
  • aurorastar22 Mar 22, 2011
    U'm pretty sure it's coming out all they way, because the alarm beeps if the door is left open for too long.
I have a Frigidaire Gallery and the control panel will not work, the fridge won't cool and the freezer will not freeze and all it does is makes a beeping sound and the interior lights come on..
Unplug it for ten or fifteen minutes. Plug it back in and see what happens. The capacitors need that time to discharge in the electronics so it can reset. If this fails the panel may be fried and may possibly be covered by warranty.
Jun 06, 2016 | Frigidaire Refrigerators
We recently had a power outage, now the interior light is flashing and the fridge is not cooling
Try resetting the fridge and freezer temp, fridge 4 deg C freezer -18 deg C turn the unit off at the power socket leave for a minute then turn on be fore resetting.
Mar 03, 2016 | Liebherr Refrigerators
Our PFS22MISBWW fridge and freezer are the same temperature as my kitchen inside. Its around 4 years old. I've unplugged it, cleaned it out, vacuumed out the back bottom area, and waited 20 minutes...
Your nicely detailed and well worded question gives all the clues needed to suspect that the
compressor motor is effectively dead. What's happening is that the motor (correctly) receives input
from the control circuitry of the frig to turn on (to cool the interior of the frig) - it turns on, quickly
overheats (within a minute or two), and then the motor's thermal shutoff kills the overheating
motor (with a "click"). Then the motor cools for awhile, the thermal cutoff eventually resets
and allows current to the motor, which tries to run again, but quickly overheats again, etc.
May 30, 2011 | Refrigerators
My model 106.53206202 compressor stops working about every six months. The interior light lights so there is power. I unplug the power cord and when I plug the power back in the compressor works fine. ...
I think the defrost timer/control board is hanging up...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Kenmore Refrigerators
Power on Interior lights on refrigerator does not operate not cool
The interior lamps fail to light up as the swittch is faulty , so replace teh door switch if a contact cleaning wont help.
Now the cooling is related to many issues, so shut off fridge to allow time of 5 hours, The restart , if the fridge does not cool , the compressor , gas pressure is done and must be checked. If cooling is present then check if the auto defrost timer/thermostat is faulty as the fridge might stop cooling after 12 hours.
Sep 29, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
INTERIOR LIGHT GOES ON AND OFF
next time it does this unplug for 20 mins and pcb will reset its self....
Sep 28, 2009 | Hoover HFA290K Bottom Freezer Refrigerator
Fridge not cold at all.
check the adaptive deffrost control inside of the refrigerator compartment, more than likely thats bad.
Apr 05, 2009 | Freezers
Refridgerator stops cooling
Check the compressor relay near the compressor on the back bottom of the fridge. Check voltage it should read about 115, up above that there is a computer sensor, check that also has a fuse on it. One of the two is bad, they are cheap part and you can find them on LG.com
Feb 09, 2009 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
550 interior lights
sonnen,
I'm going to make my first bet on the switch. Usually, this is a plunger unit on the doorframe along the line with the hinges. It is either stuck or burned out. Usually, you can dig the switch out with a small screwdriver. If the switch has only two wires going to it, you can test by shorting out the two wires to each other. This can be done with a paper clip and then taping it up. Since there is power running through these lines, it is suggested that you unplug your unit before attempting any of this. Your fridge should be unplugged for at least 5 minutes before re-connecting. If more than two wires are involved, you can still connect them all together. Sometimes, the fan is shut by a switch when the door is opened. That would be the connection for another wire. If this is the case, carefully note which wires go where before you begin.
Dec 18, 2007 | Sub-Zero 650 / O Bottom Freezer...
Samsung RS2630WW Side by Side Refrigerator Logo
157 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
