Question about Crown XTi 2000 2-Channel Amplifier
I have Crown XTi 2000 Fan to noise and never stop running. Please help
4 Suggested Answers
  • 4234 Answers
SOURCE: i need the schematic for the crown amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Dan
Posted on Jun 29, 2009
  • 1527 Answers
SOURCE: fan don't work when power is turn on
hello try and get another fan strip the wires and where the fan is connected place there. and turn if the fan spins the you need a new fan if it don't spin then the fan fuse may have blown
regards
shaun
Posted on Mar 27, 2010
SOURCE: Crown Xti 2000, signal to both channels, no sound
common problem with xti series... all the amp needs is a soft ware update contact crown and they can sort it for you... you dont have to send the amp back to them. it was a verry common fault with all the early xti amps..
Posted on Sep 23, 2010
When I on my xti crown 4002 power amps,why the fan is not on,please help me,It just new after 3 days now..
Is the fan supposed to be on. On some units it runs all the time on others when the temp hits a certail level. Which is it for your baby?
Sep 03, 2017 | Crown Audio Players & Recorders
My xti 6002 crown amplifier ch2 shows thermal protect and fan is in full speed .what is causing the problem kindly give some tips to repair it
Crown utilizes small signal transistors as thermal tracking devices but i think that this is not the main issue with the amplifier, it could be in the output stage with some power transistors failure, does the other channel works fine?
Oct 11, 2013 | Crown XTi 6002 1200w Stereo Power...
Does the input signal to the xti 2002 amp make adifferance balanced or un?
The balanced line input will be used for long runs to eliminate noise. it is low impedance.the high impedance line (unbalanced) is ok for sort runs such as in a rack. if you were say running output from a mixer 50' away you want to use the balaced output on the board and the balanced input on the amp.
Aug 31, 2011 | Crown XTi 2000 2-Channel Amplifier
Fan don't work when power is turn on crown xti 4000
the fans on these amps are heat sensitive, only when the amp heats up, then they come on
Mar 27, 2010 | Crown XTi 4000 Amplifier
Crown Xti 2000, signal to both channels, no sound out of one, swapped speakers, connectors, etc. , still no sound out of one channel
Aug 24, 2009 | Crown Audio Players & Recorders
My XTi 2000 is very distorted intermintently. Sometimes the volume drops by at least half. I tap gently on he top of the amp and it comes back up to normal. I heard Crown has had some issues. What's the...
From your description, I would suspect some poor solder connections inside. If you know how to work on these, check for bad connections near the voltage regulators. That is the mode common area.
Dan
Jun 30, 2009 | Crown XTi 2000 2-Channel Amplifier
I need the schematic for the crown amplifier xti 1000 crown xti 1000 2-channel amplifier
Dan
Jun 28, 2009 | Crown XTi 2000 2-Channel Amplifier
I have two xti 2000 amp running with electrovoice speaker 600w
This is most likely to be a heat issue where the amps overheat and shut themselves off then cool down and turn back on. Please check that the amps have proper ventilation and that any air ducts are clean.
Feb 26, 2009 | Crown XTi 2000 2-Channel Amplifier
Crown XTi 2000 2-Channel Amplifier Logo
268 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
