Question about Microwave Ovens
Je recherche une notice pour cet appareil moulinex microchef FM 5745 AGSB combi roast synchro grill
Can you help me to get Hinano Microwave Combi Grill manual?
I searched and did not find a website for your product. I suggest the following clarifications and also a follow up suggestion to find the manual.
1, I suggest you post the model number or part number with your request.
2. Is it Combi or Combo?
3. Is Hinano the brand and if so, do they have a website? It seems Hinano is a term referencing Tahiti and there are lots of hits for clothing and apparel but nothing for appliances.
Follow up suggestion:
If you find the manufacturer's website, go into google and type:
site:hinano.com Hinano microwave combi grill manual
That will search only that specific website (the one I hope you find to put in and not the official beer of Tahiti site listed above...) and google does a much better search than built in search engines on specific sites. Good luck!
Jan 15, 2018 | Microwave Ovens
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
How to use Proline MicroChef ST235?Can i use it for baking?
Hello...
BAking is not recommended in microwave.
is not recommended because the excess of humidity blasting circuits and metals.
Aug 10, 2014 | Microwave Ovens
Samsung microwave CP1395 malfunction E-32 in manual. If I use oven function or a combo like microwave & grill it stops midway and will not work again!
Bonjour
nous avions une erreur 32 sur notre four
ce n'etait pas l'element damper ci-dessus (test? manuellement)
nous avons trouv? la cause un peu par hasard : en appuyant tres tres fort sur le plateau interieur l'erreur 32 disparaissait et le four refonctionnait qqles secondes
donc :
debrancher le four
demontage de la tole de dessous le four
demontage de la piece qui detecte la presence (ou qui mesure - tres mal - le poids) : 3 vis
Sans lui debrancher ses fils electriques
avec un petit boulon par exemple et un serre joint : ecraser doucement le centre du capteur
poser le capteur er le serre joint derriere le four et remonter le four
rebrancher
ca marche
sans l'option mesure de poids mais comme c'est une fonction qui ?est pas au point c'est pas grave
stephane
bretagne
contact@armorstudio.fr
Apr 24, 2013 | Microwave Ovens
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Jul 29, 2011 | Sanyo Microwave Ovens
I need a new bowl for a Moulinex masterchef 580, is it still avasilable, where?
Try Moulinex's web site?
espares.co.uk if you are uk based stock spares for Moulinex. Or http://www.dealtime.co.uk/moulinex-masterchef-spare-parts/products
Hope that helps
Dec 31, 2010 | Microwave Ovens
Tesco Combi Microwave-doesn't cook but grills ok
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 08, 2009 | Emerson MW8777W Microwave Oven
Belling CJ ss 25 Microwave Combi
I would suspect a bad magnetron or a loose connection at the magnetron's terminals or possibly another high voltage part (such as a shorted diode or bad transformer).
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Otherwise, I would contact the manufacturer or your local microwave / appliance repair center for service.
Good luck.
May 29, 2008 | Microwave Ovens
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
