Question about Taylor 214CE-G Grand Auditorium Acoustic-Electric Guitar with Gloss Finish Natural
Recently purchased a taylor 214ce. when plugged in, it produces a distorted sound after playing for sometime. any idea what the problem might be?
  • shainepereir Mar 23, 2011
    i tried changing the batteries already. The distorted sound was still there and after sometime it there was no sound at all.
  • Taylor Master
  • 5,603 Answers
Replace the battery. Batteries tend to recover and then go down again when they get weak. Use GOOD alkaline batteries NEVER rechargeable types.
Posted on Mar 22, 2011
  • Fred Yearian Mar 23, 2011
    OK. Another problem that can happen is the contact of the jack where you plug in your guitar cable. The SECOND contact (there are actually three) on this is what connects the battery. If that contact gets bent or somehow fails, that will cause the exact problem you are seeing. The jack is a "stereo" three conductor jack and when you plug in a MONO type plug, it shorts the one contact to the barrel which complets the battery circuit. Without the battery getting to the preamp the sound will be distorted or non-existent.
I've only had my 714ce for about 5 weeks. I've used it for 4 shows and during my last show I experienced a volume drop. I unplugged the jack, plugged it back in and it was fine for a bit, bu
It's most likely the battery isn't producing enough voltage, though it may have been adequate for your other guitar.
However, you should discuss the issue asap with your dealer and/or Taylor support.
https://www.taylorguitars.com/support
Support
May 16, 2017 | Taylor 714ce Guitar Acoustic
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
Hey I recently purchased a Roland TD-4 and i have no idea how to hook up an amplifier to it. My friend gave me a little amp, and i've tried many ports and cannot get it to play outloud. I'd like it...
First plug a set of headphones into the Left audio out and see if you get any sound from there... NOTE: it will only be in the left headset and this is normal. Turn up volume control... note the level will be low as this is a line output, not headset. This is a test to see if there is audio.
Sep 02, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
I have a new Taylor 310ce. Owned it about 3 weeks. It played fine and one day i left the guitar cable plugged in. Today it would not play through my amp. Everything was plugged in securely. I...
You are likely correct that you have trained the battery. The battery is located at near the tail line.
http://www.taylorguitars.com/global/pdfs/es_guide.pdf
Jul 19, 2011 | Taylor 310ce Dreadnought Cutaway...
My ltd deluxe ec-1000(vintage black) is not producing any distortion on my Marshall mg100hdfx. this is the first time i have had an active pickup guitar, i put a new 9v battery in it but still no change in...
Distortion is not produced in the guitar. Distortion is generated in the amp by circuitry that increses the gain until the waveforms "flat top". This creates higher harmonics and a buzzy sound. If you are getting a very low output from your guitar it is possible that you don't have enough output to get the distortion in the amp to work. Other settings in the guitar add harmonics by mixing more than one pickup. This is not ditortion but adding these harmonics changes the sound immensly.
LOOK AT THIS SITE AND FIND A SCHEMATIC THAT MATCHES THE RESOURCES OF YOUR GUITAR... You might be able to figure where the wire goes... It may be a ground.
http://www.guitarelectronics.com/c=D65u46R1H9tko6CKpPLsjBhiJ/category/wiring_resources_guitar_wiring_diagrams/
Apr 24, 2011 | ESP Ec 1000 Ltd Deluxe Electric Guitar In...
I bought my Taylor acoustic/electric brand new. It sounds great, but when i plug it into my amp no sound comes out. I replaced the battery, but it still failed to work. When i plug it in to the amp and...
If you just bought the guitar, take it back. Taylor has good warranty programs, take it back to the dealer. You may have a bad connection inside where the saddle pick up plugs into the graphic preamp, the fact that you hear a sound when you put the battery in or out indicates very little. You may have a bad preamp, like I said, if its new, don't wait get it back to the dealer or contact Taylor.
Dec 27, 2010 | Taylor Guitars 816ce Acoustic Electric...
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Distortion stoped working on my amp
Hi there. Sounds like the distortion foot switch is stuck. Try a shot of WD-40 where the button goes into the switch and then click it on and off a bunch of times.
Thanks
Paul
May 28, 2009 | Music
Taylor 214CE-G Grand Auditorium Acoustic-Electric Guitar with Gloss Finish Natural Logo
344 people viewed this question
Top Taylor Music Experts
Christoverre Kohler
Christoverre Kohler
rhodesworks
Christopher White
Level 1 Expert
Are you a Taylor Music Expert? Answer questions, earn points and help others
