Question about Microwave Ovens
Je recherche un mode d'emploi pour cet appareil moulinex micro chef FM 5745 AGSB combi roast synchro grill
WHEN I SUBMITTED MY PLEA FOR HELP TO GET A MICROWAVE USER/OPERATOR MANUAL, I WAS ASKED: WHAT MAKE IS IT?
that model is from the uk,you need to search over there for it,i just searched for an hour and come up with this, Accumetrics Inc Announces United Kingdom Distribution Agreement With...
22l is how much it holds,not the model number,Elitech commercial grade steam oven/combi grill - in VGC - not used a great deal, but a very handy addition to any kitchen at busy times!
Voltage - 220-240 V input 1650 watt when on steam mode, 1250 oven/grill mode.
Dimensions 220x315x312 mm
Manual available online to download - (Ref Elitech EA053747)
Capacity 22L Instruction Manual Copy ELITECH Steam Oven Combination Grill Model Ref...
May 11, 2015 | Microwave Ovens
Tip
Have a Delonghi combi. Oven and grill work but not the micro wave is it the...
  • Problem: Totally dead oven.
    Possible causes:
    1. No power to outlet (blown fuse or tripped breaker or GFCI).
    2. Blown main fuse - likely due to other problems.
    3. Open thermal protector or thermal fuse.
    4. Defective controller or its power supply.
    5. Clock needs to be set before other functions will operate (some models).
  • Problem: Totally dead oven after repair.
    Possible causes:
    1. Cabinet screws replaced in incorrect location (safety interlock not engaged).
    2. Any number of screwups. :)
  • Problem: No response to any buttons on touchpad.
    Possible causes:
    1. Door is not closed (some models).
    2. You waited to long (open and close door to wake it up).
    3. Controller is confused (pull plug for a minute or two to reset).
    4. Defective interlock switches.
    5. Faulty controller or its power supply.
    6. Touchpad or controller board contaminated by overenthusiastic cleaning.
    7. Defective/damaged touchpad.
  • Problem: Oven runs when door is still open.
    Possible causes:
    1. Damaged interlock assembly.
    2. Cooling fans (only) running due to bad sensor or still warm.
  • Problem: Oven starts on its own as soon as door is closed.
    Possible causes:
    1. Defective triac or relay.
    2. Controller is confused (pull plug for a minute or two to reset).
    3. Defective controller or its power supply.
    4. Touchpad or controller board contaminated by overenthusiastic cleaning.
    5. Defective/damaged touchpad.
  • Problem: Oven works but display is blank.
    Possible causes:
    1. Defective controller or its power supply.
    2. Broken display panel.
    3. Oven needs to be reset (pull plug for a minute or two to reset).
  • Problem: Whacked out controller or incorrect operation.
    Possible causes:
    1. Previous or multipart cook cycle not complete.
    6. Defective sensor (particulalry covection/mirowave combos).
  • Problem: Erratic behavior.
    Possible causes:
    2. Bad connections in controller or microwave generator.
    3. Faulty relay - primary (or HV side, much less commonly used).
    5. Bad contacts/connections on mechanical timers. Intermittent fuse.
    6. Power surge at start of cook cycle confusing controller.
    7. Microwave (RF) leakage into electronics bay.
  • Problem: Some keys on the touchpad do not function or perform the wrong action.
    Possible causes:
    1. Touchpad or controller board contaminated by overenthusiastic cleaning.
    2. Defective/damaged touchpad.
    4. Faulty controller.
  • Problem: Microwave oven does not respond to START button.
    Possible causes:
    1. Defective START button.
    2. Faulty interlock switches.
    3. Door is not securely closed.
    5. You waited too long - open and close door to wake it up!
  • Problem: No heat but otherwise normal operation.
    Possible causes:
    1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
    2. Bad connections (particularly to magnetron filament).
    4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
    5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
    6. Defective HV relay (not commonly used).
  • Problem: Timer and light work but no heat, cooling fan, or turntable rotation.
    Possible causes:
    1. Defective (lower) door interlock switch or door not closing fully.
    2. Faulty relay or triac.
  • Problem: Fuse blows when closing or opening door:
    Possible causes:
    1. Defective door interlock switch(s).
    2. Interlock switch knocked out of position.
    3. Misaligned door.
  • Problem: Loud hum and/or burning smell when attempting to cook.
    Possible causes:
    1. Shorted HV diode, magnetron.
    2. Burnt carbonized food in or above oven chamber.
    3. Shorted winding in HV transformer.
    4. Frayed insulation on HV wiring.
  • Problem: Arcing in or above oven chamber.
    Possible causes:
    1. Burnt carbonized food deposits.
    2. Exposed sharp metal edges.
  • Problem: Fuse blows when initiating cook cycle.
    Possible causes:
    1. Defective interlock switches or misaligned door.
    2. Shorted HV capacitor.
    3. Shorted HV diode.
    4. Shorted magnetron (probably won't blow main fuse but HV fuse if used).
    5. Defective triac.
    6. Old age or power surges.
    7. Defective HV transformer.
    8. Short in wiring due to vibration or poor manufacturing.
  • Problem: Fuse blows when microwave shuts off (during or at end of cook cycle).
    Possible causes:
    1. Defective triac (doesn't turn off properly).
    2. Defective relay.
    3. Shorting wires.
  • Problem: Oven heats on high setting regardless of power setting.
    Possible causes:
    1. Faulty primary relay or triac or HV relay (not commonly used).
    2. Faulty controller.
  • Problem: Oven immediately starts to cook when door is closed.
    Possible causes:
    1. Shorted relay or triac.
  • Problem: Oven heats but power seems low or erratic.
    Possible causes:
    1. Low line voltage.
    2. Magnetron with low emission.
    3. Faulty controller or set for wrong mode.
    4. Stirrer (or turntable) not working.
    5. Intermittent connections to magnetron filament or elsewhere.
    6. Faulty primary relay or triac or HV relay (not commonly used).
  • Problem: Oven heats but shuts off randomly.
    Possible causes:
    1. Overheating due to blocked air vents or inoperative cooling fan.
    2. Overheating due to bad magnetron.
    3. Bad connections in controller or microwave generator.
    4. Faulty interlock switch or marginal door alignment.
    5. Faulty controller.
    6. Overheating due to extremely high line voltage.
    7. Stuck stirrer fan resulting hot spots detected by sensors.
  • Problem: Oven makes (possibly erratic) buzzing noise when heating.
    Possible causes:
    1. Fan blades hitting support or shroud.
    2. Vibrating sheet metal.
    3. Vibrating transformer laminations.
    4. Turntable or stirrer hitting some debris.
  • Problem: Oven light does not work.
    Possible causes:
    1. Burnt out bulb :-).
    2. Bad connections.
  • Problem: Fans or turntables that do not work.
    Possible causes:
    1. Gummed up lubrication or bad motor bearing(s).
    2. Loose or broken belt.
    3. Bad motor.
    4. Bad thermostat.
    5. Bad connections.
on Nov 26, 2008 | Kenmore 80412 Microwave Oven
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
Microwave ne se rechauffe pas
Premierement, assurez vous que le niveau de pouvoir est sur le maximum (10).
Si ca n'est pas le probleme, vous probablement aurez besoin d'un micro-onde nouveau.
Il y a un parti a l'interieur appeler le Magnetron qui ne fonctionne plus. Avec le cout de travaille, remplacement de cette parti peu couter jusqu'autant q'un nouveau machine complet.
Si votre machine est presque nouveau, contactez le magasin ou vous l'avez acheter, et demandez un retour ou echange.
Outrement vous devez acheter un nouveau. Essayez de faire un peu de recherche sur l'internet avant d'acheter un autre. Le modele que vous avez a recu beaucoup de plaintes de mauvais qualite.
http://www.reviewcentre.com/reviews126097.html
Desole de vous donner les mauvais nouvelles.
Merci et bonne chance.
May 12, 2011 | Neff H5430 Convection Microwave Oven
Food still cold after cooking
Is this a combi oven? If it is not-and only a micro then there is no heating element. Try it on micro(if its a combi) with a mug of water for approx 30 seconds to test it. If its a combi-is the micro function still working?
Jun 21, 2009 | Emerson Microwave Ovens
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
I need a new door for Delonghi Combi micro/grill model no. DMX30
You should be able to find help at the DeLonghi customer service site.
Mar 04, 2009 | DeLonghi Microwave Ovens
Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Dec 28, 2008 | DeLonghi MW 605 Convection/Microwave Oven
Everything works perfectly (oven, grill, etc) on my combi microwave except the microwave is it only a fuse? if so how do I change it? or should I just bin it
It is a safety fuse !but somthing has made it blow,and needs checking by microwave engineer.Possibly door interlock fault.Micros can kill even when UNPLUGGED be carefull. If you live in cheshire we can FIX IT Grandadfixer
Nov 05, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
