My LG 60PZ550 Plasma HDTV turns on sporadically when connected to my U-Verse STB via HDMI cable. This does NOT occur when the STB is either disconnected from the panel, or when connected to the panel with component video cables. No other HDMI device (ie: Blu-Ray player, DVD player, HTiB) seems to exhibit this issue with the panel, only the U-Verse STB. Any suggestions?
  • tim1483 Mar 22, 2011
    The U-verse STB is connected to the 2Wire router via ethernet (no coax is used anywhere in the system), then HDMI cable to my LG panel. I've seen some other queries on the web about similar issues with the U-Verse STB and it appears that the STB may generate CEC messages whenever there is an internal U-Verse event (recording, stop, update, update guide, new IP, etc.)
    Oh, and the 2Wire router is connected via staion wire to the AT&T network interface panel...still no coax in use.
  • 643 Answers
Reset the uverse box. try resolution output settings from box. reseat the hdmi with tv and box.
Posted on Mar 22, 2011
  • 1 more comment
    Tried all of those before I posted, but thanks!
    I also tried changing cables, but made no difference...
  • Mando Mojica
    Mando Mojica Mar 22, 2011
    is the box connected with old rg59 or new rg-6 coax? may need cable amplifier. or try with eathernet cable input to box.
  • Mando Mojica
    you may have to switch to component cables to get rid of the tv turning off and on. try going into the menu of the tv and turn off any hdmi start up options.
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Feb 25, 2016 | Sylvania Televison & Video
LG TV 60PZ550 black screen no pic or sound green lit flashing it has back lite
LG 60PZ550 Plasma - No Sound, No Picture - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Sep 15, 2013 - 20 posts - ‎4 authors
LG 60PZ550 Plasma - No Sound, No Picture Troubleshooting TVs and Video Sources. ... I see no change in the screen at any point (no glow). With the rear cover ... I've worked with some electronics in the past, but am new to TV's. I'm sure .... Multimeter on DC 1000V, red on (+) marked, black on (-) marked. Lg 3d plasma 60pz550 i've got sound but no picture
Jul 18, 2014
LG 60PZ550 color issue - Badcaps Forums
Jun 9, 2014
Purple/Pink Lines / Postering on plasma LG 60PZ550
May 29, 2014
LG Plasma 60pz550 has strange greenish rainbow ...
Jan 20, 2014
More results from www.badcaps.net
Jan 10, 2016 | LG 60PZ550 3D Plasma TV
Connect cable hdmi
Make sure the laptop has diverted its video to the HDMI port. Try this sequence. Lap top off....TV on...connect HDMI cable. Turn on laptop. Switch laptop video to HDMI if it won't do it automatically.
Dec 26, 2013 | Dell W5001C 50 in. Plasma HDTV
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
I am trying to connect my lg 50'' plasma trying to my lenovo through vga to hdmi cable ,but am not geting display on lcd.
from a cable box you must have the box in hdmi mode turn cable box off with tv on and press menu on cable box remotly scroll down and turn on HDMI
Nov 18, 2009 | LG 50PX5D 50 in. Plasma HDTV
I have hd picture but no sound, tv says hdmi audio unavailable
I called Verizon and exchanged my STB from a QIP 6416 to a QIP 7216 and it solved the HDMI audio problem. This looks like the fix.
Apr 05, 2009 | HP PL4260N 42 in. Plasma HDTV
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Plasma
if your tv is on warranty take it back to best buy for a replacement.good luck
Apr 27, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
