Question about Sylvania Televison & Video
Sylvania LD370sc8s when you turn it on 1/2 of the picture rolls the other half is ok you have to keep turning it on & off till it works
  • Irene Young Mar 22, 2011
    the screen looks like it is split in half
    the left side has lines the roll up continually and the right sid of the picture is clear and great
    you have to keep turning the TV off and on untill the full screen appears with no rolling
  • 10,594 Answers
Can you please elaborate " 1/2 of the picture rolls ", I need more info for that symptoms to diagnose problem. Apparently it seems problem with lcd panel (screen) however t-con board replacement might solve this problem. T-Con board is also part of lcd panel but available individually to reduce repair cost because lcd panel replacement cost is approx new tv price.
Thanks.
Posted on Mar 22, 2011
  • Shahid Electronics
    Shahid Electronics Mar 22, 2011
    Thanks for detailed info, I would suggest to replace t-con board of lcd pane (screen) to solve picture problem. Required t-con board is available with ShopJimmy.com (click the link to view board image and price info)
    T-Con board replacement is not user level repair so check with local tv repairman for that.
    Thanks.
S-Video won't work on my Sylvania SST4322. I have my DVD player connected via S-Video but no picture. I can get picture with just the standard cable.
I don't think video 1 is the right input for S-Video. Try different input settings on the TV setup menu, in fact try them all one by one till you get a picture. If you can't get a picture check the lead.
Sep 20, 2014 | Sylvania SST4322 32" TV
My tec ma 1450 register won't work just blinks 0.00 and none of the keys work
With paper loaded properly, turn off/unplug register, turn MA or Service key to "Blind" position (approx. 5 o'clock), turn on/plug in register. "Status-C" will print on the receipt. Some of these TEC's won't reset after changing paper, and this procedure becomes necessary after each installation of a new roll of paper.
Jul 18, 2012 | Computers & Internet
Subject; Ladies watch model 5268300. I tried to modify date but without success. I pulled-out the pin & keep rolling clockwise & backwise but the date never change= it always stays at number 24. ...
There are usually two "out" positions, fully out and half way out.
Are you pulling it too far? (if you are, the hands should move when you turn the winder)
Feb 19, 2011 | Bulova Watches
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Sylvania 6432TD turns off within a second of turning it on
Had same problem Sylvania SRT2232s 32"had to keep powering on and off until it warmed up enough to finally stay on. Problem was the 100/50 & 1/50 filter cap took it to local repair total cost to fix was 74.52 works better than ever
Mar 06, 2010 | Sylvania SRT2232S 32" TV
My Sylvania flat screen sound keeps going off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/ The most probable cause is with its audio output IC itself; overheats.
May 11, 2017 | Sylvania Televison & Video
How do I disable the alarm system on a 1998 VW beetle? I cannot start the car.
Get it bypassed ask for a good auto electrition.He will sort that out for you.hope that was usefull
Aug 01, 2009 | 1998 Volkswagen Beetle
I have a sylvania model LD370SC8S 37' i turn it on it comes on but goes to a blinking green light
i had the same problem, i just separated the wires & taped the parts where the wires came off
Jun 16, 2009 | Sylvania LC320SS8 32 in. LCD Television
The picture on the VCR keeps rolling. How do I remedy this? I have a Sylvania cca-132a2 model.
i know this may seem old-school, but try turning the vertical hold knob. it used to solve all vcr problems with rolling picture.
Jul 07, 2007 | Sylvania (SRDD495) DVD Player/VCR
Toshiba 36zp38b picture problems
With it only being about 3 years old, I would suspect bad solder connections rather than defective components like Capacitors. You may get the symptoms to come and go by slapping the side of the set or jaring it slightly which would prove the bad connection thesis. It is not a permanent cure however and you can make it worse if you keep doing that. A solder repair shouldn't run over $225 in my opinion.
Mar 11, 2007 | Toshiba 36AF61 36" TV
Televison & Video Logo
537 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
