Question about Schlage Camelot Fe595 V Cam 716 Keyless Door Lock Bronz
The latch does not retract when it meets the striker plate to close the door. this occurs in both locked and unlocked modes.
  • 604 Answers
It sounds like the latch is binding on the strike plate. you can do one of two things, move the strike plate up or down to make clearance room, or take a flat file and file down the part of the strike where the latch is getting stuck. put some chalk (chalk line type) on the strike, close the door and then reopen, you should be able to see where the latch is sticking as the chalk will be gone from that part of the latch, this is where you would file.
Posted on Mar 22, 2011
What is the part called that when the door closes goes into a slot to signal door is closed. is black and held on by 2 star bolts
The door latching mechanism closes around the striker plate, or striker, or striker latch.
Mar 26, 2015 | Cars & Trucks
Door locked and will not unlock and cant shut door
sounds like the door latch mechanism is stuck in the closed position. if you pull on the door handle and use something like a screw driver and pull the latch claws open the door should work. the latch is the part that closes around the door striker plate bolt to keep the door closed. lube the latch to help keep it from sticking again.
Sep 04, 2014 | Honda Accord Cars & Trucks
What would cause the rear door latch to work in unlock and disengage when locked?
Make sure the striker plate is adjusted right. That's the piece that the door latches on to on the door frame. It should have an adjustment. You may need a special wrench to loosen it and move it to a better position. I hope this helps.
Aug 30, 2014 | 2001 Toyota Sequoia
Latch is locked door is open
if its a side(drivers) door latch pull the door handle and using a screw driver, insert it were the striker plate would be with the door closed and pull the latch claws out apart. then lube the latch mechanism really well.
Aug 28, 2014 | Cars & Trucks
My Kwikset door handles turn, but the piece on the inside of the door will not retract far enough to allow the door to close. It gets stuck about 3/4 of the way in. Any advice?
The latch houses the retractable part that catches the striker plate. If the retractable part does not retract far enough, then possibly that might need to be defective and need to be replaced.
Aug 25, 2011 | Garden
My car door does not close,door lock is jamb
Check the latch assembly where the door closes. If the latch claw is closed it won't latch. Make sure the door is unlocked. Insert a screwdriver into the middle of the claw (circular opening where the striker latches). Open the door handle from inside or outside and pull sideways on the latch it should pop open. If it doesn't then the lock mechanism is in the lock position. Remove door panel follow lock rod to the latch and manually try to move the lever to the unlock position. If all fails you probably will need a new latch assembly.
Jan 30, 2011 | 2000 Ford Taurus
Instructions to replace door lock assembly
Hello,(1)Open the door and remove the two screws in the door lock latch plate on the edge of the door by backing them out with a Phillips screwdriver in a counter clockwise direction.
(2)Remove the two screws (located on the interior lock face plate)holding both halves of the lock assembly to the door by backing them out with a Phillips screwdriver in a counter clockwise direction,pull each side of the lock assembly from the door,using a flat blade screwdriver to pry them off if needed. (3)Pry the latch bolt out of the door by inserting the edge of a flat blade screwdriver under the latch plate on the edge of the door.slide the latch assembly out and set aside.(4)Insert the new latch assembly into the hole left by the old latch bolt.Trim the recessed opening with a sharp chisel if the new lock latch plate is larger than the old latch plate.Secure the latch to the door with the two screws provided by turning them in a clockwise direction with a Phillips screwdriver.(5)Hold both side of the new lock assembly to the holes in the faceof the door.Line up the shaft from the lock cylinder into the slotted hole in the latch assembly.Make sure the lock face plate with the screw holes is facing the inside.Attach the lock assembly to the door by turning in the screws with a Phillips screwdriver in clockwise direction.(6)Remove the old striker plate from the door jamb by backing out the two screws with a Phillips screwdriver in a counter clockwise direction.Install the striker plate that came with lock kit with the screws provided using a Phillips screwdriver in clockwise direction.
(7)Close the door and test the operation of the lock from the inside and outside using the turn lever and the key.Make adjustment to the striker plate if needed by removing the holding screws.Reposition the striker plate and replace the screws
Thanks
May 26, 2010 | Ovens
I accidentally pulled the interior trunk release of 2008 volkswag
Try a screw driver,and release the trunk release at the same time and unsnap the latch,the latch thinks it is closed,because the latch never opened back up to allow the striker to go in it and trigger the latch to close,the latch is in closed mode,you will have to manually unlatch the latch sort of speak.
Apr 21, 2010 | 2008 Volkswagen Jetta
The drivers side door won't close.
open the door , look at the latch on the door , as it get older and non lubricated , the latch can stick in the locked position , i,m going to draw a picture .
when the door is open it should look like the picture , i suggest your door is in the closed position and why it bounces off as you say , take a , lets say a screw driver stick it in where the little lever thats sticking up , push the door open button on the outside door handle , pry that lever forward , if successful try it , and lubricate it , hope my barbaric picture gets the point across .
Jan 05, 2009 | 1995 Jeep Grand Cherokee
Can't close back door without turning the knob
Try taking the knob out of the door and spraying the whole latching mechanism with WD40 or some kind of lubricant. There is a few moving parts in there that can get bound up. Hope this helps. Don't forget to leave feed back.
Nov 26, 2008 | Top Knobs Hardware & Accessories
Schlage Camelot Fe595 V Cam 716 Keyless Door Lock Bronz Logo
915 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
