Question about Honda 25cc 4-cycle Mini Tiller
I HAVE TRIED ALL THE IDEAS REMOVE SPARK PLUG,INSERT SMALL AMOUNT OF GAS ETC. IT HAS GAS AND FIRE BUT NO START
    President:
  • 2,468 Answers
If you say it has fire,then the small amount of gas you poured into the spark plug hole will fire if theres a spark,if it does fire when this is done its your carb thats fouled up,remove the air cleaner from the carb and when it fires,take WD-40 and spray it into the carb where you removed the air filter&cover and see if you can keep it running,also did you remove the sediment bowl off the bottom of the carb to see if and how much water/dirt is present in this bowl???
Posted on Mar 22, 2011
Lawn mower will not start,but turns over...how do I find a fix?
Remove air filter and pour a small amount of gas directly into the carb. Try syarting. If it runs then dies off you either need a carb rebuild or you have no fuel getting to the carb. Please be careful as if it backfires the fuel can catch fire. It only takes a very small amount...a teaspoon or so for this test.
Aug 01, 2016 | Craftsman Garden
I have a craftsman model # 316.791020 will not start have replaced with new carburetor new module new spark plug cleaned muffler plenty of fire through plug fresh gas tried small amount of gas in cyl
Remove the muffler and make sure your ring isn't seized to the piston. You should be able to move it feely. If you can't isn't not likely you're going to get it to start. Check compression too. Sometimes there simply isn't enough compression to fire the plug no matter how much spark and how much fuel.
Sep 23, 2014 | Garden
'88 Mazda 323 cranks, but won't start.
I wouldn't flood one cylinder and expect it to start. Try using a small amount of starting fluid in the air filter to confirm your plug wires are installed and working correctly.
Mar 26, 2014 | 1988 Mazda B2200
Yard machine y25 no start
Remove spark plug and pour in a small amount of fuel install plug and try to start it will fire the amount you poured in try this a few times
Mar 02, 2014 | Yard Machines Garden
Have now replaced sparkplug , spark module , checked for spark , took spark plug out put small amount of fuel in hole dipped spark plug in fuel replaced tried to start and nothing not even a pop how i
If it has been sitting a while then the gas lines may have gotten brittle and broken inside the gas tank. Look in there with a flashlight. Dipping the spark plug in fuel wouldn't nessesarily work.
Mar 12, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 3105 Toro trimmer that won't start. Things I have tried is replacing the spark plug. Trying fresh new gas. I have checked for spark and seems that it shows spark . Can you help me?
If you can get it to fire by adding a small amount of the fuel/oil mix directly into the air intake, then you have a fuel system problem and either the carb or fuel line are at fault. Depending upon the amount of use the trimmer has had, it can also be an ehaust port constricted with carbon.
Jun 25, 2011 | Garden
My pressure washer doesnt seem to run properly. i have changed the fuel,air filter,spark plug and the oil. It will start but runs poorly.
Ok the first thing you need to check is if the spark is fireing. To do this you need to remove the plug plug it into the spark plug cap hold it on the cylinder head pull the engine over it will pull easy and see if you have a blueish spark jumping the gap on the plug . If you do its not an electrical prolbem . Then put the plug back and plug the ignition wire back and remove the air cleaner see if it will start then .witch the choke on . If it still won't start try pouring a small amount of fuel derictly into the carbuator if it runs for any time at all or even starts to fire then its a fuel issue eighter bad fuel or clogged filter or carbuator needs to be cleaned. You can even put a small amuont of fuel right into the spark plug hole then put the plug back in and it should start You need spark fuel and air for any engine to run if you have all three its automatic it will at least fire Good luckwith this
May 22, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
I cant get my coleman powermate 5000 MAXA ER to start. i have changed the oil, refilled the gas, changed the spark plug, and tried using starter fluid. what else can i try?
It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
Feb 02, 2011 | Coleman Powermate Premium Plus 6250W...
Just will not start
You have most likely done this but lets go back to the basics.
Do you have spark at the plug?
Check to see if the plug is fouled - pull the plug connect to the plug wire- ground the metal part of the plug to the metal body of the engine - as you turn the engine over it should fire cleanly from the center to the electrode, if it fires off to the side or has an orange colored spark it is fouled - replace it.
Once we have spark check for gas is it getting to the carb?
90+ % of all small engines not running are due to the fuel line or in tank screen being plugged with garbage. Remove the fuel line from the carb, point it down and using a small container to catch the gas it should flow freely.
If you have good gas flow reconnect the fuel line to the carb and put about 1 CC of gas in the plug hole reinstall the plug and fire it - almost all small engines use a bit of vacuum to pull the fuel from the carb into the cylinder, jump starting them with a very small amount of gas directly in to the cylinder can help them get going.
A VERY SMALL AMOUNT OF GAS AND CLEAN UP ANY SPILLS BEFORE YOU TRY TO START !!
Burning down the house will upset the other half
Mar 08, 2010 | Briggs & Stratton Garden
Honda 25cc 4-cycle Mini Tiller Logo
285 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
