Code 10 - Computers & Internet
    Brigadier General:
  • 8,909 Answers
Code 10 means there is a driver/some drivers that are corrupt/in the wrong place.
Run iobit.com and registry utility.
Run CHKDSK/F
Any other problems can be fixed by downloading the latest drivers from the manufacturers web site and that should fix it.
Posted on Mar 22, 2011
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
Code 65535 what does that mean
How do i remove t-mobile content lock with out credit card or by going to t-mobile shop.
Apr 05, 2013 | Cars & Trucks
Authentication code sound forge pro 10.0
serial for Sound Forge pro 10164-41PJ-D3SJ-1LK6
Authentication code
D1WYYWZG6-B60EB12XN-QYQXY55RQ-4KXSPFKXK-ZK5P7Y1TE-HZ5941KRY
Apr 16, 2012 | Sony Sound Forge Pro 10 for PC
Dvd error code 10
Cause of the Code 10 Error A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
The safest thing to do is to perform system restore or
run SYSTEM RECOVERY.
If you will use sysem recovery it fix all the problem of your computer however all files on your hardrive and softwares that you installed will gone.
It will be back from original manufacturer settings just like the same thing you got your computer.
Dec 30, 2011 | Sony VAIO S360 Notebook
What does 10-5 mean?
Ten-codes, or 10-codes, are codes used in two-way voice radio communication as numeric code words for frequently used messages.
  • 10-5 ->relay this information to ___.
  • References to 10-codes LINK
    Hope it helps.
    Apr 27, 2011 | Audio Players & Recorders
    I JUST WANT THE CODES FOR CHEVY TRAILBLAZER 2004...
  • Feb 7/11 - P0405
  • Jan 11/11 - P0336 - P0326
  • Dec 28/10 - P0217 - P0218 - P0163 - P0230 - P0231 - P0232
  • Dec 9/10 - Trouble Codes: P0170 - P0173 - P0162 - P0154 - P0142
  • Dec 6/10 - More DTC articles: P0157 - P0158 - P0160 - P0200
  • Nov 30/10 - DTC articles posted: P0505 - P0156
  • Nov 18/10 - More new articles: P0143 - P0144 - P0146 - P0147 - P0152
  • Nov 12/10 - P0120 - Throttle Position Sensor/Switch A Circuit Malfunction
  • Nov 11/10 - ECT Circuit Codes: P0116 - P0117
  • Nov 10/10 - P0111 - IAT Circuit Range/Performance Problem
  • Nov 7/10 - P0110 - Intake Air Temperature Circuit Malfunction
  • Nov 6/10 - P0108 - Manifold Absolute Pressure/Barometric Pressure Circuit High Input
  • Oct 21/10 - P0216 Injection Timing Control Circuit Malfunction
  • Sept 11/10 - Knock Sensor DTCs: P0327 P0332
  • Mar 15/10 - P0607 Control Module Performance Code
  • Mar 4/10 - P0606 PCM Processor Fault DTC
  • Feb 10/10 - New ECT Sensor article
  • Feb 9/10 - P0012 & P0022 - Camshaft Position - Timing Over-Retarded
  • Feb 2/10 - P0115 - Engine Coolantmag-glass_10x10.gif Temperature Circuit Malfunction DTC
  • Jan 19/10 - P0105 - MAP/Barometric Pressure Circuit Malfunction
  • Feb 10, 2011 | 2004 Chevrolet TrailBlazer
    Green light flashes, will not print. Checked all
    Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Bush rf668vpl tv
    Most TVs have the buttons on the side that you can hit when the remote is broken. generally they are hard to see and usually on the right side, but can be on the front, underneath too.
    another user:
  • View public profile
  • ">Recurve360 on a site called boards Bush Universal Remote Control Code said to try these codes:
    One for All URC 7930 codes for Bush TVs: 0614,1037,0660, 0714,0037,0668,1652,0218,0163,0009,0036,
    0371,0282,0355, 0363, ,0519,0264,0361,0487,0208,0217,1556,0698... 0778,1259,1982,1248,1916, 0587
    Dec 03, 2017 | Televison & Video
    Need to learn 2-way radio codes like 10-20 10-4
    Hi rgsusmcret79
    Here is a full list of the codes, however, not all of them are used popularly. The list at the end are the more common ones.
    • 10-1- Receiving Poorly
    • 10-2- Receiving Well
    • 10-3- Stop Transmitting
    • 10-4- Ok, Message Received
    • 10-5- Relay Message
    • 10-6- Busy, Stand By
    • 10-7- Out of Service, Leaving Air
    • 10-8- In Service, subject to call
    • 10-9- Repeat Message
    • 10-10- Transmission Completed, Standing By
    • 10-11- Talking too Rapidly
    • 10-12- Visitors Present
    • 10-13- Advise weather/road conditions
    • 10-16- Make Pickup at...
    • 10-17- Urgent Business
    • 10-18- Anything for us?
    • 10-19- Nothing for you, return to base
    • 10-20- My Location is ......... or What's your Location?
    • 10-21- Call by Telephone
    • 10-22- Report in Person too ......
    • 10-23- Stand by
    • 10-24- Completed last assignment
    • 10-25- Can you Contact .......
    • 10-26- Disregard Last Information/Cancel Last Message/Ignore
    • 10-27- I am moving to Channel ......
    • 10-28- Identify your station
    • 10-29- Time is up for contact
    • 10-30- Does not conform to FCC Rules
    • 10-32- I will give you a radio check
    • 10-33- Emergency Traffic at this station
    • 10-34- Trouble at this station, help needed
    • 10-35- Confidential Information
    • 10-36- Correct Time is .........
    • 10-38- Ambulance needed at .........
    • 10-39- Your message delivered
    • 10-41- Please tune to channel ........
    • 10-42- Traffic Accident at ..........
    • 10-43- Traffic tieup at .........
    • 10-44- I have a message for you (or .........)
    • 10-45- All units within range please report
    • 10-50- Break Channel
    • 10-62- Unable to copy, use phone
    • 10-62sl- unable to copy on AM, use Sideband - Lower (not an official code)
    • 10-62su- unable to copy on AM, use Sideband - Upper (not an official code)
    • 10-65- Awaiting your next message/assignment
    • 10-67- All units comply
    • 10-70- Fire at .......
    • 10-73- Speed Trap at ............
    • 10-75 -You are causing interference
    • 10-77 -Negative Contact
    • 10-84 -My telephone number is .........
    • 10-85 -My address is ...........
    • 10-91 -Talk closer to the Mike
    • 10-92 -Your transmitter is out of adjustment
    • 10-93 -Check my frequency on this channel
    • 10-94 -Please give me a long count
    • 10-95 -Transmit dead carrier for 5 sec.
    • 10-99 -Mission completed, all units secure
    • 10-100 - Need to go to Bathroom
    • 10-200 - Police needed at ..........
    . The common ones that are wellworth knowing are
    10-1
    10-4
    10-7
    10-8
    10-9
    10-10
    10-20
    10-100
    Receiving Poorly
    Received
    Out of Service, Leaving Air (you're going off the air)
    In Service, subject to call (you're back on the air)
    Please repeat
    Transmission Completed, Standing By (you'll be listening)
    Location, 'What's your 10-20?'
    Toilet, 'I'm going 10-100'
    I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
    Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
    regards
    robotek
    Jun 18, 2008 | Audio Players & Recorders
    Computers & Internet Logo
    26 people viewed this question
    Alun Cox
    David Payne
    David Payne
