Question about Mongoose Currie Schwinn Gt Izip Scooters
I have a izip a izip bicycle and i am not getting power to get it going how do i troble stoot it in ordor to get power thank you albert winkfield
How to rewire my electric bike
Have a look at the owner's manual, the wiring diagrams start on page 27 if viewing in Adobe reader or page 52 of the manual itself. http://www.currietech.com/dealers/wiki/images/0/04/Owner%27s_Manual_-_Bicycles.pdf
Most connectors only have one other connector at the controller that they can plug into. Brake levers are in parallel, so can plug into either.
Feb 08, 2013 | Electric Izip Mountain Trailz Al Men Bike
Izip electric bike wont start
If the battery cells have been load tested and found OK then You need to trace the output voltage (using a voltmeter) from the battery to the controller to confirm you have voltage at the controller when the power is switched ON. If there is no voltage at the input to the controller then trace the voltage on components between the controller and battery, such as the switch and fuse and all the connectors.
If there is full battery voltage at the input to the controller then suspect the controller is faulty.
Jun 09, 2012 | Electric Cycling
Hi I bought a second hand Schwinn AL1020 a year ago. It seemed quite zippy. Now it is very slow and needs to be charged every night for a 16 km round trip and seems to be dying further away from home...
Since you bought it second hand and then used it for another year, it is very likely that the battery is getting closer to the end of its days, as it should. You could order a new one from Currie, they manufacture the batteries (and I think also the bike).
http://www.curriestore.com/37-izip-via-mezza-battery-pack.html
Aug 16, 2011 | Cycling
I have an izip ladies electric bike the back wheel wobbles already adjusted it.
You will need to tighten your bearings (The inner nuts when you remove the back wheel) Or you may have to tighten your freewheel this takes a special wrench and probally should be done at a bike shop.
Aug 30, 2009 | Electric Izip Mountain Trailz Al Men Bike
I have a izip ladies electric bike the back wheel is wobbly though we have adjusted it
Have a look here under Servicing cup and cone hubs:http://sheldonbrown.com/wheels/index.html Hope this helps.
Aug 30, 2009 | Huffy Raven 26-Inch Dual-Suspension...
My compute canot see my printer
Hi albert, I would suggest you update your printer drivers, try this, it should help:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 21, 2008 | HP Photosmart D5069 InkJet Printer
Red stanby light flashing and wont turn on. Model is hitachi tv l42vp01u. Any idea? Thanks
Mine has just done the same and the power board has been taken away by tv tech for repair, seems the power board on these vestel/hitachi tv's are not very good. Fourth one I have learned about. Stoots
Jul 31, 2008 | Televison & Video
Mongoose Currie Schwinn Gt Izip Scooters Logo
50 people viewed this question
Top Mongoose Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Mongoose Toy Expert? Answer questions, earn points and help others
