Question about Health & Beauty
Pads lost their performance and they do not cooparate with the main base, Do I need new pads or is there something wrong with the base? If I could not fix it,Where Can I buy a new one and how much it shoud coast? The model of my enstrumant is OMRON HV-F122 Elepuls. Sincerely yours, Erol ALTAN
Mix-it-up
  • 832 Answers
SOURCE: Error # 46 - Absorption Pads need replacing
same issue (plz read my answer here):
http://www.fixya.com/support/t202282-unable_print_unable_int_unable_clean
Posted on Feb 08, 2008
SOURCE: Top row of pads don't work, can I fix them? MPC2000xl
go here:
http://www.mpcstuff.com/pad-sensors-with-ribbon-for-mpc.html
there is also an install video.
i have the same exact problem.
best,
m
Posted on Apr 23, 2009
c17hydro
  • 2984 Answers
SOURCE: I am replacing the rear pads and cannot get the
One, take your brake fluid reservoir cap off.
Two, use a thin piece of wood to help you compress the piston on the caliper....do it slow. This way, you don't create a lot of pressure to the reservoir and it won't overflow.
Three, these are the steps to removing and replacing the pads for the rear. It does mention a special tool....but you can use a c-clamp for the same purpose:
Rear To Remove:
  1. Check the brake fluid level in the brake master cylinder reservoir.
  2. If required, remove the fluid until the brake master cylinder reservoir is half full. CAUTION
    Care must be taken when servicing rear brake components without disconnecting the parking brake cable from the brake caliper lever.
  3. Remove the disc brake caliper. Support the caliper with mechanic's wire. CAUTION
    When the brake pads are separated from the brake caliper, new brake pads must be installed. The brake pads are one-time use only.
  4. Remove and discard the brake pads and spring clips from the brake caliper anchor plate. NOTE: Do not remove the anchor plate guide pins. The guide pins are press fit to the brake caliper anchor plate. If the guide pins are damaged a new anchor plate must be installed.
  5. Inspect the brake caliper anchor plate assembly.
  6. Check the guide pins and boots for binding or damage.
  7. Install a new brake caliper anchor plate if it is worn or damaged.
To Install:
NOTE: The left caliper piston turns clockwise and the right caliper piston turns counterclockwise.
  1. Using the special tool, turn and compress the brake caliper piston into the cylinder.
  2. Clean the residual adhesive from the brake caliper fingers and pistons using the specified brake parts cleaner. CAUTION
    Do not allow grease, oil, brake fluid or other contaminants to contact the brake pad or caliper mating surface. Do not install contaminated pads.
    NOTE: Install all the new hardware supplied with brake pad kit.
  3. Install the new spring clips and brake pads.
  4. Position the brake caliper and install the 2 bolts. Tighten caliper bolts to 23 ft-lbs (31 Nm).
  5. If necessary, fill the brake master cylinder reservoir with clean brake fluid.
  6. With the engine running, apply pressure on the brake pedal to seat the brake pads.
  7. Test the brakes for normal operation.
Posted on May 17, 2009
  • 14036 Answers
SOURCE: Replacement brake pads for 06 Lexus GS 300?
go with standard pads.they wear a little faster than ceramics.but they dont wear down brake rotors.ceramics pads are hard and they cause brakes to squeak.also your car is under warranty with lexus dealership.i would use what they said. because you have future brake problem. they will void out warranty for not using their brakes.
Posted on May 29, 2009
  • 14036 Answers
SOURCE: grinding noise in front wheel just changed pads not pads
sound like front wheel bearings badly worn.
Posted on Nov 16, 2009
Hopefully it's just the brake pads that need replaced on my car?
Sounds like brakes but you have to see the pads to be sure. If you drive long with bad pads, your rotors should be turned as well. Look at your pads... If there is metal on metal, go put pads on. If you buy most pads from a place like AutoZone, they are guaranteed for life. Which means wherever you feel like replacing the pads again they are free. You can either take your old pads into the place BUT I prefer to buy them again and swap the pads. Put the old pads in the box and take them back. They refund you... Free pads for life
Oct 18, 2017 | Cars & Trucks
Squeaking Brakes
What kind of brake pads are you using and did you use brake grease on the pad's baking plate. Lubriplate (blue squeeze tube) makes it, et al. Ceramic pads last longer, but have a tendency to squeal a bit more than OEM or HD (sport) pads. Akibono are best ceramic pads on the market, with ATE, Jurid, Textar, and Galfer about equal in performance pads. Ultra high performance pads are made by Brembo, Galfer (Spain), AP (UK) used by GM, and EPC.
Jan 04, 2015 | Interface Lincoln Zephyr 2006 06 W/nav...
Had new pads installed in the front and rotors were turned. Now I hear a sound as if one of the brakes pads touching the rotor. It stops when I bearly apply the brakes. Sometimes If I ride the brakes It...
Without going into all sorts of detai,l of
how brake work should be performed
I will say something wasn't done correctly &
you need to go back and find out what
I would guess that no rust was removed from
any components, and you new machined rotors
do not run true
You really need to do all you own vehicle work,
if you want to avoid this sort of poor professional
work, that is all over the industry
Mar 26, 2011 | 2002 Mercury Sable
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cleanilng ink absorber pads
boil them till the ink starts coming out then rinse and repeat if nessisary "DO NOT OVER BOIL"
Mar 27, 2009 | Epson Stylus RX580 InkJet Photo Printer
Skweeking brakes
Several possible causes:
  1. Did you use copper-based brake grease on the brake pins and the back of the pads?
  2. Did you clean all the old gunk off the brake pins and after doing so, where they deeply grooved? If so, you must replace them.
  3. Wrong brake pads. Some pad manufacturers list a patricular pad as being OK for a vehicle. They fit OK but the pad characteristics are wrong and they squeal like crazy or wear out in no time or give lousy raking performance etc.
  4. If the pads you removed had anti-squeal shims on the back of them did the new ones? They almost certainly should have. IIRC, they are held to the pads by some double-sided adhesive tape.
  5. If you get squeak-silence-squeak-silence... at low speed (i.e. just before coming to a halt) then the disk(s) is/are distorted. They will have to be replaced. You must not machine the discs on these brakes - there is no thickness available to do that. If you do tthey may well collapse under the heavy braking of an emergency stop with very unfortunate consequences!
  6. As someone said, the disc may be badly worn and/or grooved -check and replace if necessary.
  7. You may have a stone or piece of grit stuck between a pad and a disc. If so & it's worn a groove in the disc,you will need to replace both disc and pad.
  8. Make sure you torqued any brake bolts correctly and that you put thread sealant on them. Failure to do so can lead to them loosening in normal use. The brakes may squeak for a while if this happens but then things can get much worse...
Sep 18, 2008 | 1995 Volvo 850
Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
Jan 22, 2007 | Maytag Legacy Top Load Washer
Health & Beauty Logo
81 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
