Question about Brother MFC-7340 All-In-One Laser Printer
I AM USING A BROTHER MFC 7340 SINCE 1 YEAR: NO PROBLEM EXCEPT WHEN PRINTING FROM PAPER TRAY, THE PRINTER SQUEAKS AND MAKES NOISE THAT IF ANYTHING ELSE WAS DOING THE SAME NOISE YOU WOULD THINK IT NEEDED LUBRICATION. THANK YOU FOR YOUR SOLUTION. REMI
  • Basca Nov 18, 2011
    I have the same problem. What is user serviceable area, where exactly should I lubricate?
  • 79 Answers
The problem actually is probably due to needing lucubration. I would apply graphite lube to any rollers or gears in the user serviceable area. print 100 blank pages to make sure that the lube is spread thoroughly through the printer.
Good Luck!
Posted on Mar 22, 2011
When I try to print on the MFC 7340, the paper tries to load but stops and a message appears that the paper tray ihas no paper.
It could be the springs that push the paper up are worn out or maybe the rollers are old and worn down.
If the rollers are worn down you can order a maintenance kit and replace them yourself.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
When printing from paper tray, the printer squeaks and makes a noise that if anything else was doing the same noise you would think it needed oiling.
I would oil it. Printers need lube too. I would use graphite lube because it is thick and wont spread except from where you put it.
Mar 22, 2011 | Office Equipment & Supplies
My Brother MFC-7340 squeaks very loudly when printing. Is there any way to prevent this from happening (any place to oil)?
Certain Brother models have this problem. It is a loose screw on the fuser cover assembly. Instructions for tightening this screw are here. You don't need to grease anything - in fact it tells you not to lubricate this gear. Easy fix, took me 10 minutes!
Aug 28, 2010 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC 7340
If it is A4, it is too much paper and it is too heavy, it can damage the lift gear. Put half of quantity.
Feb 01, 2010 | Brother MFC-7340 All-In-One Laser Printer
Problems printing to Brother MFC 8660DN printer
Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
How i load paper for brother mfc-7340
Here is the link where you can get the manua;l for that printer.
MFC-7340 Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 09, 2009 | Brother MFC-7340 All-In-One Laser Printer
How to print adhisive labels using mfc 7340
Buy laser-specific adhesive labels. Those that say "Laser printer compatible". If you have an inkjet printer, print the labels with it, with the laser is more risky because of the temperature the paper needs to get in the printing process. If one label gets out of the support paper or the paper gets sticky inside the printer, it will cause a real mess.
Try inkjet first, or buy high-quality labels and print one full sheet at a time, not label by label.
Oct 28, 2009 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-7340 All-In-One Laser Printer Logo
1,484 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
