Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How to take a whirlpool clothes washer agitator out of the washer to be replace
    Sergeant:
    Champion:
  • 218 Answers
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Posted on Mar 22, 2011
    • Rejeanne Dyck Feb 07, 2012
      How to loosen the bolt that hold the agitator? We've tried WD-40 and lots of muscle but it won't budge.
    • 27 Answers
    SOURCE: Top load Whirlpool washing machine
    Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
    Posted on Nov 02, 2007
    • 1073 Answers
    SOURCE: Whirlpool Ultimate care II Washer Agitator not turning
    replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
    Posted on Apr 16, 2008
    SOURCE: replacing spin belt whirlpool clothes washer
    There is indeed a drive belt to the imperial 70. Problem more likely is in the 'wig-wag' unit that engages and disengages the spin clutch and the agitator drive
    Posted on Sep 10, 2008
    • 61 Answers
    SOURCE: Clothes come out extremly wrinkled on top loding whirlpool washer
    this machine spins at an extreamly high speed.if the load is to small the clothes will tangle together and wrinkle. it is normal for the clothes to be spun realy tight and come out of the washer nearly dry this is designed to cut down on drying time and save energy.
    Posted on Jan 19, 2009
    SolutionGuy
    • 331 Answers
    SOURCE: Agitator does minimal agitation
    Hi Omni,
    The Agitator "dogs"/cams have given up the ghost and need to be replaced. Access to them is easy. Before starting the repair, have this part in hand.
    Here's a tool list;
    1.) small flat screwdriver (to remove the top part of the agitator)
    2.) 3/8" ratchet
    3.) 8" X 3/8" extension (for the ratchet)
    4.) 7/16" socket
    Take a gander at this pic... you'll be going after #10 'cause that's the problem.
    All you gotta do is remove the top parts from the agitator to access it. See #2 in the diagram? That's the bolt holding the agitator to the transmission shaft. Remove that, then lift the whole agitator out of the tub. Now place the agitator on the floor and put both of your feet on the base. Now lift the agitator (#3) off the base (#4). Place one of your hands into the opening of the top of the agitator (to hold the cam (#9) in place) then turn the agitator over. The cam will slide right out.
    Now you'll see the cam "dogs"... little white curved plastic doo-hickeys. All you gotta do now is install the new cam assy. and rebuild the agitator! Cool, huh? All it takes is about $15 bucks in parts and ~20 minutes.
    Let me know if you have further questions. And don't forget to rate my solution as "FixYa"! Thanks, BB
    Posted on Apr 14, 2009
    Washer won't agitate with clothes in. Will agitate when empty with water
    It's a whirlpool top load and 17 years old.
    I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
    When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
    What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
    Nov 26, 2012 | Whirlpool Washing Machines
    What is the agitator
    The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
    Sep 26, 2011 | Whirlpool Washing Machines
    How do i replace the agitator in my old heavy duty whirlpool washing machone?
    Hello.
    The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
    Thanks.
    Sep 07, 2011 | Whirlpool Washing Machines
    Whirlpool cabrio washer - a piece of clothing is stuck under the agitator - how do I get it out
    Take off the cap on the agitator and remove the bolt. The agitator should pull off and you can rescue your clothing item.
    Manual and parts list click here.
    Hope this helps.
    Zeppelinx12
    Feb 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    My washer got overloaded with clothes and now it will not aggitate or drain "whirlpool"
    Remove agitator and check the spines if worn replace agitator. remove hoses and water pump and check for anything clogging them. also, check the belt for signs of ware.
    Jul 27, 2009 | Whirlpool LCE4332P Top Load Washer
    We have a Whirlpool LLR6144AQ0 washer. It fills
    Drive coupling / agitator dogs are probably shot. This is the most common problem these types of washers have. Parts replacment link is here: http://www.appliancepartspros.com/part_details.aspx?part_id=3138838
    Jul 13, 2009 | Whirlpool Washing Machines
    Slow spinning agitator with knocking sound
    agitator dogs. take them out and replace.
    Feb 28, 2009 | Whirlpool Washing Machines
    Clothes mover of whirlpool top-loading washer is loose. Agitates.
    You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
    Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
    Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    1,039 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
