Question about Amana Washing Machines
Model # lwm353w was not agitating. Changed belt. Worked normal after that. Notice water leaking from bottom. Changed the water pump. Stop leaking and worked fine again. Now agaitates slow or if at all. Does the humming noise in the beginning. Sounds like it's working but moves slow if it is moving at all. What should I do now? Thanks
  • 883 Answers
SOURCE: My washer, while draining, leaks from the bottom.
remove the panel to observe the drain hoses while machine is in use. using a flashlight, locate the hose that you see leaking.
Posted on May 31, 2007
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Posted on Oct 28, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
  • 1044 Answers
SOURCE: WILL NOT AGITATE, SPIN OR
Open the back cover and start the washing cycle. When the agitator cycle begins check if the motor rotates. If it does not and the humming sound comes there is problem is withe motor. Also check the tightness of the belt. Even if it is loose it does move but it is slippery movement unless it is completely loose. Anyway the problem is with your motor and the connecting bearing/pulley. You have to ask a technicians to help you out
Posted on Sep 29, 2010
1999 CHEVY SILVERADO 1500 COOLANT LEAK
I haven't worked on that vehicle but in my experience it probably is the water pump. That is how you know when it goes bad
Apr 25, 2016 | 1999 Chevrolet Silverado 1500
My washing machine is a whirpool stylemaster model no. LXR9245EQ2 and it will not do anything besides put the water into it and it will only halfway drain. It does not agitate at all.
If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically.
Here is the switch to order.
The part comes with a 365 day, any part, any reason return.
Nov 07, 2012 | Washing Machines
Water is leaking from the drivers side as soon as you fill it with out the car being on it is a 1988 Honda civic dx hatch back
There is something called a "weep hole" on the water pump. Water seeps out of this hole to let you know the water pump is bad. It is to the lower right of your driver's side motor mount right below the head, but it's on the side of the block. From the bottom you will notice this leaking all over your lower plastic timing cover. When you change this pump you are also supposed to have your timing belt changed.
Sep 22, 2009 | 1988 Honda Civic 2 Door
1994 Honda Civic LX\overheating within 2 mile drive
Remove and raise upper hose at thermostat end and remove lower rad hose.
Fill rad with a hose and watch for flow from bottom rad hose and/ or bottom rad hose connecton.......water should fall though rad easily.
Honda rads are cheap.....any restriction....replace rad.
Remove thermostat....fill thermostat housing with hose and watch for water flow at bottom rad hose.
Flush good.
Remove heater hoses.......flush back and forth until a good flow is present "With heater control set to hot" if no or poor flow....replace heater core.
Stop leak can plug everything.
Also.......not likely causing over heating....but ....at your mileage,if you do not know if the timing belt has been changed.....CHANGE IT NOW!
Water pump is optional at this mileage.
Aug 23, 2009 | 1998 Honda Civic
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Neptune washer will not go past the first wash cycle
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag washer leaks badly around the bottom on the spin cycle
Sounds like you might need a new pump belt. They are inexpensive and easy to replace. Unplug the washer and with the water out tilt it back so that you can see the bottom. You have a main drive belt that goes from the motor to the big pulley in the middle. There should be a second belt that goes from the motor to a smaller pulley which is the pump. Make sure that this pulley turns freely in both directions. One direction is agitate and the other is discharge. If it does and your belt is loose a new belt might do the trick.
If the pulley does not move freely take off the front panel, two philip screws about 3 inches up from the bottom of the front panel. Inspect the pump. One time I found a scouring pad in the pump!! If after inspection the pump still does not move freely you may need to purchase a new pump. Find the part number and check out prices on-line. The pump is relatively easy to replace. Good Luck
Jan 26, 2009 | Washing Machines
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
