Question about Drills
I need to order parts for a 16 speed drill press, chuck bt1017-jt3,arbor bt1017-mt2/jt3,and key drift bt1017-16103008. Model number BT1017. I tried calling the number on the back of my manual but cant get through.
  • 2,176 Answers
This is a technical support site, but if you give me the model and brand of the tool I will try and find an alternative route for you to order these parts. Let me know and I will do what I can to help
Posted on Mar 23, 2011
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    I need to find a chuck, part #JT3,I think.
    sounds like you need a morse 3 taper chuck or you can buy sleeves if its a morse 2 taper anyway not enough information ? is yours a morse taper or is it a screw in chuck? engineering supplies usually stock chucks or machinery shops, as an example try looking at this web site http://www.machines4u.com.au/search/?action=browse_search&industry_id=2&category_id=31 this company is called (machines4u.com.au) they have branches in all states
    regards pete Sell or Buy Drilling Machines Second Hand Drilling Machines for sale...
    Mar 21, 2015 | Drills
    Alternative chuck key specifications
    Delta is always creat problem.
    If you want to find best drill press open the link Black Bull 16 Speed Drill Press Explained
    Jan 17, 2013 | Drills
    I have Clarke metalworker model bt1001a drill press, looking for a manual and chuck key, were can I get one?
    chuck keys can be found at amazon for good prices, take a look here: Amazon com chuck key. I hope this was helpful. Cheers
    Oct 29, 2012 | Drills
    NEED CLARK MODEL BT1001A CHUCK PART NO.DDJ2216
    Ideal that the part can be sourced from the dealer or the nearest hardware/accessories stores.Please check with your nearest dealership in the location.
    Jan 17, 2012 | Drills
    Dayton drill press, How do you remove the chuck? It has a Wilton 1/2 chuck 3z568 model
    If the spindle has a slot in it above the chuck and you can see the top of the chuck arbor in that slot then you need to get a wedged piece of steel commonly called a drift , insert in the slot so it bears on the top of the arbor and the top of the slot and hit it with a hammer. This will knock the tapered arbor loose from the spindle and it should fall out. Hope this helps you.
    Jan 26, 2010 | Drills
    Chuck falls out of drill press
    There is a long tapered hole in the spindle of the press known as a Morse taper. It holds a 6 or 8 inch morse taper arbor which is attached to the drill chuck. This is made to be removed frequently by putting a wedge shaped key into a horizontal hole in the drill press and giving it a little tap. This is for making tool change that involve removing the chuck. If you had two such tools (say two different style chucks) they would each have their own dedicated morse taper arbor. But there is also a short tapered cyclinder on the chuck end of the morse taper arbor, with a matching hole in the back of th chuck. This is not intended to come apart frequently, but it can be disassembled. I'm not sure which one is coming apart, but regardless of which one it is, you might try this fix. Clean up any bumps at all on the oustide of the taper and inside the hole with sandpaper 200 - 300 grit. Use a dowel to hold the sandpaper in the hole, and use the motor to spin it. --- JUST BE CAREFUL that if it grabs that it doesn't grab you! Once it's all cleaned up, you can you the press aspect of the drill press to seat it in place. You also might have to replace the arbor. They don't cost all that much and are available from Grizzly.com. You specify the particular taper for BOTH ends of the arbor. The long end is a Morse 2,3 or 4, and the short end is specific to the drill chuck manufacturer, like JT-2 (Jacobs chuck taper 2). Write back if you need more help.
    Jan 07, 2010 | Drills
    Hi, I have a Clarke Drill Press Model No:- CDP 12HBN
    You can get a universal chuck key at Home Depot, Lowes and many other tool outlets. They have 4 different keys in one.
    Nov 24, 2009 | Clarke Power Products Clarke 16-Speed...
    I have lost the chuck key where can I get a new
    Go to your Ace hardware store ... if they dont have one on the shelf, they can order any size you need. Go with the make, model etc of your drill.
    Let me know if this helps you
    a
    Sep 21, 2009 | Clarke Power Products Clarke 16-Speed...
    PRO- TECH DRILL PRESS BENCH MODEL
    parts can be found on amazon, take a look here: Amazon com Drill Press parts. I hope this was helpful. Cheers
    Jul 19, 2009 | Delta 15 331 15" 115/230V Variable Speed...
    Drills Logo
    94 people viewed this question
    Top Drills Experts
    Are you a Drill Expert? Answer questions, earn points and help others
