Question about Riso RZ220 Duplicator
I can not open the master roll unit. I push the button and do not hear the beep or get a green light. Unit will not pull out
  • 132 Answers
If you look on the front cover of the master roll unit you will see a small round hole take a screw driver and push it in the hole when it wont go in further pull on the lever and the drum should come out
Posted on Mar 22, 2011
How can the master roll be opened without the use of the release button?
by using & insert a pencil or 4mm screw driver , press manually master unit release switch on master unit cover ( small hole ) on bottom side of master unit cover and draw master unit by other hand
Mar 02, 2015 | Riso RZ220 MASTER UNIT - ONE ROLL PACK
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Light rolling from green to red
stephen I think you are in sleep or lock out mode. Try turning the power on and pressing the horn button twice see if it stops scrolling if it doesn't turn the power off then turn it on and immediately push the joystick forward until you hear a beep then immediately opush it to the rear until you hear another beep then release it to the center. If it is in lockout you should see it return to normal lights Hope this helps
Nov 14, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Our garage door is not opening with the wall unit or remotes. When I push the wall unit I hear a click from the ceiling unit. The door operates fine manually. The green light on the ceiling unit (the SRT...
The green light on the motor unit is an LED and random flickering is normal. Your problem is most likely caused by an electrical storm or power surge. You will need to remove the logic board from the motor unit and check for burnt or missing traces on the printed circuit board especially around the small transformer. Your holding that button in will most likely have erased the memory of the unit and all your remotes will need to be programmed once you find your problem. I really suggest you call an technician at this point.
Oct 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Sep 23, 2010 | Deadbolt Locks & Locksmithing
My rizo 220 wich cannot pull a muaster roll
Normally when this model does not feed the master,there is a drive band jump off it place n the master drive unit.To correct this open the front panel of the master making unit and check that all the drive bands is in place.I am working 10 years with Riso and this machines is the best I ever worked with.
Nov 26, 2009 | Riso RZ220 Duplicator
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
Craftsman Garage door opener not working
First, check the springs in the actual door to make sure that they are not broke. Since you held the learn button down to reset the opener, you have to reprogram all of your remotes. This button only resets the remotes. It has nothing to do with the rest of the opener. To reset the opener, simply unplug it for a couple of minutes and then plug back in. Pull the handle on the door and see if you can operate the door manually with one hand. If it takes more than 15lbs to move the door, there is a problem with the door balance. If the springs are not broke and the door operates smoothly, the likely cause is the rpm sensor on the opener.
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
316 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
