Question about GE Washing Machines
When i wash there is a lot of sand particle in the botom of the machine.
DO you have well water? If so change the filter on your pump.
Posted on Mar 22, 2011
What will happen if the stand pipe o-ring is bad?
The Hayward Pro Series Sand Filter uses an O-Ring on the stand pipe to separate water returning to the pool, after being filtered, from water coming into the filter from the pool. If this O-Ring is broken, missing or sufficiently worn, small particles of dirt and sand can by-pass the sand filter and return to the pool without being properly filtered by the sand filter.
This can be especially evident just after backwash and rinsing of the sand filter bed. During this time water flows up through the sand bed, opposite the direction in normal operation. This forces the top-most material of the sand bed to dislodge and wash out of the filter to waste. It can also force fine particles to enter through a faulty O-Ring into the pool return stand pipe. Then, when returning the filter system to normal operating mode, those fine particles enter the pool through the water return piping and collect on the bottom of the pool -- mostly small sand particles but potentially filtered debris particles that were captured on top of the sand bed.
To avoid this problem it's wise to replace this O-Ring every few years. And make sure to follow the manufacturer's recommendations regarding the amount of sand to fill when replacing sand. It's important to keep the top of the sand bed at the correct level to insure proper filtering and minimize stray particles coming back into the return water.
Aug 11, 2014 | Hayward SAND FILTER, PRO SERIES
Sand in the bottom of washer
I PRESUME U MEAN INSIDE"? OUTSIDE? SOME HAVE A CERAMIC COUNTER WEIGHT AND WHEN IT WEARS U WILL FIND SANDY PARTICLES ALL OVER
Jul 25, 2014 | Kenmore Washing Machines
I have a 5.5kg Top Load Fisher & Paykel Washing Machine MW512. The clothes seem to come out with alot of dust particles on them. Is there somewhere in the washing machine where it is collecting this...
Hi - are these particles kinda ash grey black in colour? if they are then the bellows have sprung a leak.. unfortunartely the only way is to replace the inner stainless drum.
Inspect the top of the bowl for any signs of structural damage along the grey plastic housing as it contains very fine sand used to counter balance the inner bowl.. on rare ocassions these leaks and give you the particle effect similar to what you've described..
Aug 12, 2011 | Fisher and Paykel Fisher & Paykel Washer
Water keeps dripping after a cycle
Sounds like you have a bad solenoid in your water valve. A new one is probably needed. Alot of times, sand and other particles form inside from the sediment and don't allow the solenoid to close properly.
Mar 09, 2010 | Maytag Washing Machines
Food particles and what looks like sand consistently left on dishes after cycle is finished
Clean the filter.  It is at the bottom below the wash arm.  Remove the wash arm by lifting it off.  The filter is a round ring the can be lifter out and cleaned.
May 20, 2009 | Dishwashers
After the clothes are washed and dried there are some sand particles on the clothes. What could be the problem?
Sand in your washing tub that is not being evacuated after washing.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Brown material
I f you use liquid fabric softener you will get allot of weird things inside the machine building up and eventually falling off onto the clothes.Rust will also have the same effect,if you can see it ,sand it off ,and cover the area you sanded with a sealer and let dry for 24 hrs. Please Rate This !
Jul 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Small Particles Sand & White color particles from dispersion screen group head & in water
I had this happen about 6 months ago. It was the heating element. I had to have it replace - about $225. Ugh. But it works great now. Good luck. If you have an espresso repair shop you can take it to, they can hook it up to an electrical tester and let you know if it the element.
Jun 08, 2008 | Rancilio Silvia Espresso Machine
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
