Question about Sony KP-61S75 TV
3 yellow horizontal lines in upper 1/3 of screen on Sony KP-61S75
Just tonight, 3 horizontal yellow lines appeared. They do not go completely across the length of the screen. We are on cable-checked another television and the picture does not have the lines. Any help would be appreciated and thank you in advance.
  • dr dt Aug 05, 2008
    Thank you. It turns out to be the digital converter box. When the box is bypassed, the lines go away.
  • 10,594 Answers
TV has problem in convergence circuit. Needs qualified technician.
Posted on Aug 03, 2008
Sony kp-ws500 has very fine red and blue horizontal lines across screen tried adjusting convergence, and it didn't do anything
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Sep 16, 2010 | Sony KP-65WS500 65" Rear Projection...
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Thin red horizontal lines appear when viewing a dark background
Look around this sight the answer is explained here. you hace to take off the front speaker cover and a small panal undder it. you will find six knobs on a small panal. use these to adjust the settings fotr the power and they will remove the lines. You will need to have the tv on and I would sugest a normal size phillips head screwdriver not a power tool.
Jul 26, 2008 | Sony KP-51WS510 51" Rear Projection...
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Kp-61S75 sony
i have wiring diagram
Aug 16, 2007 | Sony KP-61S75 TV
A "Gray Scale" adjustment may solve you problem. If one of the picture tubes is set too high it will cause these RETRACE lines. Then too a weak picture tube might cause this. If the horizontal lines are one color: red, green,or blue then whichever color that is shown would tell you which tube is set too high. Your set has 3 screen controls that control the brightness of each tube. One may need to be turned down a little. Stargazer
Mar 11, 2007 | Sony KP-46S25 TV
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Sony KP-61S75 TV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
