I have the wireless router WTR54GS. My laptop was working fine and then it won't work. I have also tried to connect a wireless printer and I can't do that either. The wireless card on the laptop has been checked and is fine. It works fine elsewhere. We are currently using a laptop and a PS3. We have four ports on the router. Please help.
  • 96 Answers
Plug in a utp cable in a lan port (there are 4 ) from the router.
The other plug in the lan port from your laptop.
Open a dos window and type ipconfig.
There you see a set of numbers like 192.168.1.1
Open a webbrowser, and type in the adress http://192.168.1.1 or the adres wich you found.
Now you are in the router webbased configuration. You need your login name and password, usual something like admin and admin.
There you can set all of youre wireless settings.
Posted on Mar 22, 2011
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
I can detect my Linksys Travel Router but cannot connect to it...ive tried to connect 2 different lap tops both can detect the router but cannot connect to it. I am using Windows 7
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jun 24, 2010 | Linksys Wireless-G Travel WTR54GS Router
Was working fine, moved to another apartment down the hall, now it won`t even show under wireless connections, but i can connect to any unsecured network in our building and hardwire my laptop into the...
Considering How thick the walls are... the signal from your router may not be able to go through plus all the other EMI devices like Chordless phone etc.
Try Setting up the router in an open area suitable for a better signal for your laptop.
Apr 04, 2010 | Linksys Wireless-G WRT54G Router
I need to change my password for my WRT54GS router.
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Mar 02, 2010 | Linksys Wireless-G Travel WTR54GS Router
My wireless laptop won't connect to network printer using netgear router . When hard wired over LAN, printer works. Cannot ping when laptop is wireless. Other computers work fine. HELP~
  • laptop has to be connected first to SSID
  • then ping is possible
  • or else reset the wireless settings: change SSID name, channel 6, and no password first
Jul 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Jun 02, 2009 | Canon PIXMA MX850 Multifunction Printer
Netgear MR814 won;t connect
wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
Mar 04, 2009 | NetGear MR814 Wireless Router
Comcast says my old WRK54G router is defective. Should I replace it with WRT54GS (Walmart $55) or WRT54G2 (Staples $64). (2 home PC's & occasionally laptop-pretty heavy internet...
Since your WRK54G is already bad, I will advice you to get this WRT54GS router because i can tell you that it work fine and the connection is much faster compare to this WRT54G2 and WRT54GS is pretty much stable compare to the WRT54G2 since I have work for Linksys for almost 3 years...
DOn't forget to rate the solution FIXYA thank you...........
Oct 17, 2008 | Computers & Internet
Can not connect to router from laptop
You need a wireless printer server to get your printer to work.
Apr 20, 2008 | NetGear RangeMax WPN824 Wireless Router...
Computers & Internet Logo
David Payne
David Payne
