I HAVE A SCOTT HOME THEATER SCS60 WITH A MISSING DIN CABLE 8 PIN . WHERE CAN I GET ONE?
    Problem Solver:
  • 6 Answers
Please find below the following websites where you can order for the DIN Cable 8
http://www.cablestogo.com/product_list.asp?cat_id=928
http://www.nextag.com/8-pin-din-cable/products-html
Posted on Mar 22, 2011
How to solder new cable bose acoustimass 8 pin din
get solder iron to low set up on circuit board with silver solder
Aug 28, 2014 | Bose Audio Players & Recorders
8-pin din to rca adapter
check the link bellow. You will some of them. Choose wich suits your purpose.
8 Pin din to rca
Ajin
Jul 25, 2012 | JVC TH-C3 System
WHERE CAN I BUY A SP PWM505 CABLE THAT GOES FROM MY RECEIVER TO THE SUBWOOFER? ITS A HOME THEATER
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Oct 11, 2011 | JVC TH-M505 System
I CANT FIND A SP PWM505 CABLE
Regards, Tony
No sound
To answer this one, we'll need a lot more information. The following
1. Verify your cable. There's no way to post a picture so we'll try this in text. Looking at the 5-pin DIN (called P1) with the pins to the top, number them 1 through 5 from left to right (regardless of how they may be numbered on a connector as it is unmarked on the cable). Looking at the 8-pin mini DIN (called P2) with the key at the top, number the top row 1 through 3 (left to right in all cases), the middle row 4 through 6 (pin 6 will be the one separated by a gap from the other two), number the bottom row 7 and 8.
Now, make sure that continuity exists. This is how my cable was wired as follows: P1-1 to P2-7, P1-2 to P2-8, P1-3 and P1-4 to P2-6, P1-5 to P2-1. If you do not show that each wire is good, then you either have a damaged cable or audio is not being output by the Bose control unit or your system uses a different cable wiring, which means that you will need to verify that your cable connects each 5 pin DIN to some on the 8 pin mini DIN
2. Make sure that a headphone is not inserted in the headphone jack on the side. If it is, then sound in not connected to the rear ports. It may sound silly, but someone may have connected headphones and nobody realized that they're still connected.
3. Do you have an oscilloscope? If so, then you'll need to insert wires into the 8-pin mini DIN connector for the zone you're using. Using the pinouts from step one for the cable connector will create a mirror at the Bose jack as follows, left to right, top to bottom 3, 2, 1 - 6, (gap) 5, 4 - 8, 7.
Audio comes out at pins 7 and 8. So connect your scope at those points and ground the probe by clipping it to one the RCA shields. Turn the unit on and make sure that you have a source producing signal, such as a disc or a radio station and see if you see signal. The output at these pins appears rather low, so you set your scope sensitive enough.
My Bose produced audio, but also clicking at an increasing frequency and amplitude as the unit heated up, that results in a lot of noise. I verified the wiring and output with this method.
Feb 18, 2011 | Bose Lifestyle 20 System
Where can I buy the 8 pin cord ?
try jvc web site www.jvc.com the last time i was on their site i saw 8 pin din for sale.Try it good luck.
Dec 22, 2010 | JVC TH-C3 System
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
Is the system cable wired as a serial connector
u can get one from cablesondemand.com 8 pin mini din male/male
Oct 19, 2009 | JVC TH-M303 System
Nakamichi Sound space 8.5 Home theatre system
check www.dalbani.com and see if you can get these parts.good luck.greeting from Belize my email is nicodhem@yahoo.com
Apr 04, 2007 | Nakamichi SoundSpace 8.5 System
Open Questions:
128 people viewed this question
 Grubhead
Grubhead
