Question about Sharper Image Ionic Breeze GP SI720 Air Purifier
I got the prong on the plug a bit wet. i dried it off and waited, but when i did plug it into the outlet, it made a short hiss and now it doesn't seem to work at all. I'm referring to my ionic breeze
You will probably need to replace the plug you can buy them at almost any hardware store or radio shack
Posted on Oct 17, 2008
Hand vacuum doesn't charge
If the plug in charger works, the batteries are boiled out and need replacement.
They should not be left on charger all the time. Just charge them for 10 hours and use them until the performance has dropped off, then and only then put it back on charge for 10 hours.
Sep 28, 2012 | Dirt Devil Extreme Power Wet Dry Hand...
It will not turn on it says it locked how do i get this off of the screen and get it to turn on quiet flow is the nameof it
Crystal, first turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging the unit back in. After you plug it in, turn the Master ON/OFF Switch to ON and set the controls as you wish. Hopefully, during that 12 - 15 minute timeout, the unit reset itself and should now work normally.
If that doesn't solve the problem, you can call Hunter Technical Support. In the US dial 888-830-1326.
In Canada dial 866-268-1936
Apr 15, 2011 | Hunter Air Purifiers
Makes hissing sound, then immediately clicks to "clean"
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 28, 2009 | Ionic Pro TURBO Air Purifier
MOdel CA-500 is making a type of hissing sound. Almost like a zapping sound.
Dec 15, 2009 | Ionic Pro CA500 Air Purifier
Ionic Breeze Repair
Ionic Breeze GP. Unit was working. Removed insert to clean. Now the unit will not turn on.
Jun 11, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Breeze - Black Quadra won't stop hissing
I have the same problem. The one thing that I DID notice is that it seems to occur more often in winter. Thus, I attributed it to dryer air conditions--too much static electricity being the culprit. With the unit off, I sprayed a fine mist of water into the housing and that cured it for a (albeit-short) time. Best solution would be to increase the humidity via a humidifier...
Jan 30, 2009 | Air Purifiers
One hissing one shut down
I have two Quadras not sure about the GPS. The only way to clean them properly is to complete the folowing steps. This will eliminate the hissing noises and intermittent shutdowns. Clean the blade unit as normal and leave it out of the unit. Unplug the unit, remove the four phillip screws on the top of the unit where the collector grid slides down. Next remove the four screws holding on to the base of the unit. After this you will see two additional screws also by the base that need to be removed. Look carefully between the grills of the unit and you will see about 12 to fifteen tiny screws that hold the grill together. After these are removed take off the UL label and seprate the grill. You may have to gently pull up on the top where the power switch is located. I have found if you use a lightly dampened scotch brite pad to carefully clean the two wires works best. Clean the wires and pins at the bottom and make sure all is well. Use a microfiber or lint free cloth to gently wipe everthing down and make sure the unit is dry. Put it back together and put the UL sticker back on.
Feb 12, 2008 | Air Purifiers
What does a blinking blue light indicate?
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Jul 07, 2007 | Sharper Image Ionic Breeze GP SI720 Air...
The low button light is going out.
Oct 24, 2006 | Ionic Pro 901P2RIP04 Air Purifier
Sharper Image Ionic Breeze GP SI720 Air Purifier Logo
54 people viewed this question
Top Sharper Image Air Purifiers Experts
martinmarty
Ken Thomas
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
