Question about Altec Lansing ATP 3W Computer Speakers
ATP3 intermittency problem
I have intermittency problem with my ATP3. I didnt know if it was because of the power switch that goes with the volume knob or a problem with the power suppply. What i did is to check on the supplies. i think its doin OK (output of the regulator is 9V) but it goes too hot.tried to remove the 7809 and measure the load for the 7809 and it read 50 ohms. is this normal? with the instruments that i have, I cant further isolate where the problem really is. cant opent the left satellire spkr. anyone who knows how to solve this?
I've had intermittent speaker problems with these models and it was caused by slight abuse, ( stress on the speaker jacks at the main board located in the main subwoofer cabinet). The problem can lead you to believe its the speakers or the wires but in my case it was a loose solder joint on the main board in the subwoofer. I had to take the subwoofer apart and carefully re-solder the connections of the speaker jacks. I've had no problems since. I've also been a little more careful not to push the jack side of the connection against the wall, kicking with my feet etc..
Posted on Apr 18, 2009
Power trafo altec lansing atp3
Is the label missing? All the information is printed on a label or stamped into the plastic housing. Have you opened it? Many have an internal fuse you can replace.
Jul 15, 2014 | Audio Players & Recorders
I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Jan 10, 2013 | Audio Players & Recorders
I have a Kenwood stereo integrated amplifier R-42XL that I bought 25 years ago. It has served me very well and still does intermittently. Sometimes when I plug into the mains the red light on the volume...
our company has always said anything can be fixed its only the price that varys i think you have a fault in the switching mech as the unit is 25yrs old they didnt use digital switching back then i think your unit has the old spring loaded power button the problem is that the small spring behind the latch comes loose after many years and needs to be set correctly so take it to a shop and see if they know about spring switch resetting to see if this is deffinitly the problem push the button in hard if the power comes on but goes of as you realease it theres ya fault
best of luck
please take the time to rank my reply
Dec 01, 2010 | Kenwood Audio Players & Recorders
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Speakers cutting out at higher volume
Check the power /voltage printed at back side of speaker ,test w/ volt meter /if supply not enough current to drive the amplifier.The sound are very low and humming.
Jan 02, 2008 | Audio Players & Recorders
Altec Lansing ATP3
there is a lose connection near the main speaker .When i move it sound stops
Dec 17, 2007 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP3 volume control/power know gone bad
hi i used to have the same problem opening the satellite speakers of atp3 (left satellite, the cord was pulled and snap from the inside). i found out how to open them but there's a good and bad news. the good news is i know how to open them, the bad news is that it will cause some damage on your satellite speaker.a friend of mine used to have the same speaker he accidentally drop one of his satellite speaker (left one) and the bottom cover just crack open following the joint line.
the satellite speakers of atp3 has no connecting screws , it is assembled using a sort of super glue. here is how i opened my satellite speaker.
i used a flat screw driver (i sharpened it a bit to easily penetrate the joint) to shove the bottom cover of the speaker starting from the back part (near the cord) then slowly made my way around when the cover start to snap from where i started. you can remove the bottom cover this way but be aware that it will cause some damage on you speaker. i started shoving from the bottom back part because the damage is unnoticed when you reassemble it using a super glue and i use a black paint to hide the discolored plastic casing cause by force opening.
i hope this help a bit
J3n c",)
Mar 26, 2006 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP 3W Computer Speakers Logo
269 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
