Rudd central unit , turn A/C on[therm. inside] all U can hear is a Buzzing noise coming from the outside unit , found that [1] capacitor wire had been BURNT , changed wire , then changed capacitor , turned unit on[inside], 1st nothing ???? went inside & ck'd *breaker box* , fuse is operated by "dual arm[tied together] flipped off then on & went back turned a/c back on , came on for [maybe couple of minutes] then STOP'd , tried '1' more time , all U hear is the BUZZ noise? U could smell SMOKE & HEAT coming off [electric motor] , lifted top , tried to touch electric motor BUT it was tooooo HOT to touch ? We are {99.999%} sure that wired Capacitor correctly???? Want to make sure that if replace Electric motor that SHOULD be able to get A/C unit running again. THANK U *****
    Genius:
  • 1,400 Answers
Hello
Before you buy a new condensor fan motor check the contacts to the motor are not worn or pitted.
Hold or push the contactor in by using an insulated screwdriver and see if the fan motor turns.
Also the start cap you bought? was it the correct one meaning mfd micrfarad?
If all the above checks out ok then you need a fan motor,you can wire the motor direct to check it also.
From what you describe it sounds like the fan motor is burnt up and worn out,not uncommon.
Posted on Mar 22, 2011
It is a Ruud UAKA-024JA2 combination of air conditioner and central heater. The outside air conditioner fan stopped running but buzzed. The capacitor is out of order. Do you have instructions how to locate...
I'm not sure how you determined that the capacitor needs replaced without being able to check it. But the capacitor is the round tube attached inside the box. It will have several wires coming from the top. it sits down in a round hole and is held in place with two screws. Rudd usually (although not always) have gray plastic capacitors. note when you disconnect the capacitor which wires go to herm (that is your compressor) fan and common. Usually the fan is brown and the compressor is yellow or orange. there are usually two wires on the common. Note how many microfarad the capacitor is and replace with same rating. the 5 microfarad side is for the fan. I would however replace the whole capacitor.
Aug 25, 2011 | Ruud UAMB Air Conditioner
I have a Ruud condenser on which I just replaced the capacitor and contactor. When I power up, the fan motor spins very slowly and a buzzing occurs about every 15 seconds. The buzzing sounds like it's...
Hello Zing77,
I understand that you are having a problem with your Rudd condensor. The fan is turning slowly and the compressor is making a buzzing noise which has a Diversitech hard start conected to the capcitor.
You have already replaced the run capcitory on the unit and have attached the compressor wire to therm and c and the fan to therm and fan. The hard start kit shoudl be attached to the therm and c with your compressor wires attached to the same place. The hard start kit is to give the compressor the extra push (electrical charge) to start.
You need to check your connections and make sure that you purchased the proper run capcitor. If you have purchased the proper compacitor and the connections are right then you have a bad fan and the compressor as gone out on the unit.
Thank you for choosing FixYa.com
Justin
Mar 27, 2011 | Heating & Cooling
Amana central air conditioner unit rce60a2a.fan not spinning.thermostat fine and breakers on.buzzing noise on outside unit.any reset buttons or any advice?thanks, ryan
I would say the Capacitor outside has failed and the bussizng would be the contactor trying to start the unit. If you are able to pull the capacitor and go pick one up at an electric motor place then that would be the cheapest way and they could test it first
Aug 20, 2010 | Amana Heating & Cooling
I need help with a buzzing sound in my air conditioner.
It is probably the compressor humming. They can make some funny noises especially on start for a while. If the unit is not cooling it may be the start capacitor or the comressor may be locked up.
Jul 19, 2010 | Goodman CLQ36AR49 Air Conditioner
I have a cple18-1c at my home. it is making a
Fan motor is out or possibly the capacitor to the fan is bad. Would have capacitor replaced first then replace the motor if the capacitor didn't solve you problems.
Good Luck on repairs
Dave
Dec 08, 2009 | Goodman CPLE24-1 Air Conditioner
My central ac unit is blowing air that is cool but not cold
Ek chiz sukha ho to 2kg gila ho to 1kg and jal jaye to 3kg its urgent please
May 18, 2009 | Heating & Cooling
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Central air conditioner doesn't cool
no cooling means outside unit is not operating due to
-no thermostat signal
- condenser dirty need cleaning
- fan motor stucked 90% this the reason of noize
Apr 27, 2009 | Heating & Cooling
My air conditioner stopped working.
lets check do you have plug something els in the outlet to check for ac curent? the cable of this unit have an overload braker? need more info but better call a tech...good luck
Aug 11, 2006 | Kenmore 6000 BTU Single Room Air...
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
