Question about Electrolux Dishwashers
ANTI FLOOD DEVICE ACTIVATED - Electrolux Dishwashers
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
SOURCE: Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
Posted on Jan 10, 2010
joe_lishman
  • 192 Answers
SOURCE: anti flood device has activated on my zanussi
The anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water.
Posted on Jan 18, 2010
BElectric
  • 1140 Answers
SOURCE: THE anti flood device has
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Posted on Oct 17, 2010
  • 56 Answers
SOURCE: anti-flood device activated
Check your debris trap usually found at the bottom of dish washer and clean. May need to reset or unplug to reset devise. See what happens after cleaning, good luck, best regards.
Posted on Jan 31, 2011
What is code.30
Zanussi ZDF 511 User Manual
anti flood device is activated,call for service
Mar 31, 2015 | Electrolux Genuine ZANUSSI ZDF511...
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 | Dishwashers
Not taking in water , manual says anti-flood device has activated
Hi, It could be that but it could be something more simple...
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Apr 01, 2011 | Dishwashers
Anti-flood device activated
Jan 30, 2011 | Zanussi 23 in. ZDT6255 Built-In Dishwasher
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
Oct 17, 2010 | Dishwashers
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
Dishwasher starts but after a pre rinse it won't
This sounds like the anti flood device has activated (due to some water on the bottom base of the washer) This device shuts of the water inlet and puts the pump out motor on (the sound you are hearing). Nothing els happens until the water on the base is dried and the faulty pipe / leak rectified.
The anti flood device is a small polystireene plate connected to a micro switch on the bottom of the washer.
Jan 20, 2010 | Dishwashers
Anti flood device has activated on my zanussi ZDF231,also there is quite aloud whirring sound ,like a motor struggling to work
Jan 18, 2010 | Dishwashers
Dec 17, 2009 | Dishwashers
Mar 22, 2008 | Dishwashers
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
