Question about Canon imageRUNNER 2270 Copier
Can not get the copier to pull paper from the top draw with out jamming each time.
  • 1,219 Answers
first, pull out the top drawer and open the right lower cover and door. now if you look into the "hole" where was drawer, on right side you will see the 3 rollers that pick, feed and separates the paper.
Remove all rollers and clean them with alcohol and dry them out, or change the places with rollers from lower drawer. Also when the right door are opened you will se two axis with two rubber rollers, clean them very well.
The iR2270 has issues with pressure on lower right cover and you need to put the rubber or similar in wide and narrow slot on lower cover, so that when its closed presses the inner paper guide which touches the rollers on axis. If You already have metal "wings" on lower cover, you don't need to apply any additional pressure.
But necessarily change the roller for paper of both cassete's and in fixing unit the fixing cleaning roller.
Hope that helps!
Posted on Mar 26, 2011
How do i fix the paper jamming which happen in my copier machine ricoh 2027at the second,third fourth drawer?
you need to check does the sensor on the drawer which is on the right side front of the drawer, does correspond with the paper inside the drawers.
Oct 10, 2016 | Ricoh Aficio Office Equipment & Supplies
How do i clear the error code c0910?
Second draw lift ensure no PAPER is in the back of the draw jammed between draw and back of copier. Also check the no paper is being stored in side the draw all paper is the right side of the draw DO STORE EXTRA PAPER IN THE DRAW NOT DESIGNED FOR it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 21, 2014 | Minolta Di3010 Copier
Hw do i fix my minolta dialta di 552 for continuous paper jam
Where is it jamming, which draw are you using have you tried different draws or the by pass tray? Does it jam when copying versa printing? Have the draw rollers been cleaned? jamming in the fuser the hot part or under the drum before the fuser?
Mar 09, 2013 | Minolta Office Equipment & Supplies
Media jam upper tray. what does that mean?
Top draw has a paper jam media=paper or the bypass tray or where the paper exits
Oct 11, 2011 | Minolta magicolor 2200 DeskLaser Printer
HP C4280 draws a sheet of paper into the printer, paus;es, and then gives me a paper jam message. I have followed some of the suggested remedies from web sight but no success. Found light dust on rollers...
If this has not been done yet. open up the top cover and remove the print cartridge and trays. You should then gain access to the internal parts and roller. Inspect for debris. Clean out the internal parts using isoprophyl alcohol. Let me know if this works.
May 09, 2011 | HP PhotoSmart C4280 Laser Printer
Any tips on how to remove paper from printer,paper jammed underneath draw
pull out cassette and lift up the printer, look carefully for paper stuck, if not paper there pull out cartridge and inspect to samo piece of paper, just look carefully; in final open rear cover and look for a paper, good luck
Jan 31, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Brother printer mfc-8860dn
This usually means that it isn't picking up paper at all. Draw and x on the top paper and see if it takes it. You may need a new feed tire or different paper.
Apr 28, 2009 | Brother MFC-8860DN All-In-One Laser...
Keep getting message rear draw open
If you pull the fuser out, look at the bottom of the sliding mechanism for a bent metal tab that actuates a switch when you close the rear drawer.
They get bent pretty easily.
Jan 22, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Jul 20, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Canon imageRUNNER 2270 Copier Logo
70 people viewed this question
old marine
old marine
