Question about Brother MFC 7840W Printer
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to print commands, it's either asleep or the printer status says it's offline. We receive faxes but that's all.
    Novelist:
  • 129 Answers
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Posted on Mar 28, 2011
Where do you find corona wires on Brother 7840W printer?
The wire is on the drum (where the toner cartridge fits in). The green or blue piece slide cleans the coroner wire.
Jul 23, 2014 | Brother MFC 7840W Printer
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Mfc 7840w wireless printer through bell router
How do I connect a Brother MFC 7840W printer to a Bell Network. Every time I try to connect, I get a connection NG message on the printer. Any help would be greatly appreciated
Nov 14, 2012 | Brother MFC-8870dw Wireless Multifunction...
How do I reset the drum counter on the a Brother MFC-7840W???
open the front cover of machine ( where the cartridge is installed), then press the clear button, and then press 1 for yes for change drum question.
May 13, 2010 | Brother MFC 7840W Printer
How do i scan? using a brother MFC 685-cw..can't seem to use the scanner.. anyone help?
I have a Brother MFC 7840W and have struggled with the wireless features. Not sure how you have this configured but if wireless suggest you find a way to connect via LAN or USB...I cannot make mine work via wireless but hardwired works fine. To fix, I had to 'reset' the MFC (functions on the MFC itself) and then reinstall the software selecting USB as the connection method. Sounds crazy but once I did it worked.
Apr 18, 2010 | Brother MFC-685cw InkJet Printer
Can I change a document into a PDF with this printer MFC 7840W printer?
not likely..pdf convertors are from a variety of vendors, but are software applications. see adobe.com for one version.
Nov 22, 2009 | Brother MFC 7840W Printer
How to scan with brother mfc 7840w
Just put the scan job in the scanner and press the scan tab in your printer the scan image will appear in your directly connected machine/pc.
Oct 24, 2009 | Brother MFC 7840W Printer
How to remove time and date stamp on prints for Brother MFC-7840W
your instal software is defalt or remove printer software and install new driver then solve your problem
Jul 10, 2009 | Brother MFC 7840W Printer
Brother MFC-7840W Printerwill only give me Scan To FTP option now
i had the same issue - was previously able to scan to a number of different formats, then switched modems, providers and then only the scan to ftp option came up.
took me about an hour to figure out the solution, but now it works
for windows users: * go to your control panel * go to the scanners & cameras section * your printer/scanner should show up here * right click on it and select 'properties' * select the network settings tab and then -- enter in the correct ip address here OR -- specify your machine by name (enter in name here)
hope this helps!
Jan 18, 2009 | Brother MFC 7840W Printer
Brother MFC 7840W Printer Logo
270 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
