Question about HP Computers & Internet
I have a HP PAVILION a6700f desktop when I turn on the computer the scren turn black and the top says '' ISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER '' my question is, How and where I can get it...PLEASE NEED HELP...!!!!
  • gmecep Mar 22, 2011
    Carloadria i need Help...!
    Guru:
  • 571 Answers
Thank you for using fixya.
You are experiencing a no boot issue in the computer. It means that the computer does not load up the operating system. It might be caused by system failure or errors in the operating system, or missing files in the core of the operating system. What it's asking for is the Operating System's Disc enable for it to fix itself.
Here's what you need to do:
1. Look for the disc that came with your computer. It's called Microsoft Windows Operating System. If you are using Windows 7 in your computer, then, it should say Windows 7 INstallation DIsc or WIndows 7 operating system's disc.
2. Insert it in the DVD drive.
3. Restart the computer. Once you see the "press any key to boot to cd" message on a black or blue screen, press any key. It will then load up the disc and it will ask to install or repair the operating system. You don't need to install the operating system, so select repair.
4. Follow the on-screen instructions until it will tell you if the repair is successful.
Inform me if the same problem occurs after the doing the procedure that I have provided you. Just leave your message by commenting in this post. And, I'll return to you as soon as possible.
CARLO
Posted on Mar 22, 2011
  • Carlo Adrian Canon
    Carlo Adrian Canon Mar 22, 2011
    Please give me more details of the issue that you are currently having.
    Did you try the procedure? What happened?
How do i find the os on my a6700f hp desk top. will not boot to see
Check around the tower and there should be a factory label stating all the information of the computer.
Sep 03, 2012 | HP Pavilion a6700f PC Desktop
How do i find what os my hp a6700f has. it want boot.
There should be a factory label on the tower. The label should state everything you need to know.
A6700f PC Desktop crashing
Try the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 28, 2012 | HP Pavilion a6700f PC Desktop
"disk boot failure, insert system
You should have a recovery cd, it will allow you to reinstall Windows. If you don't have even that then either borrow one from a friend and use it with you key (the one on the sticker), or order a new disk by following this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07143&cc=us&dlc=en&lc=en&product=90387
Jul 30, 2011 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Hp pavilion a1210n disk boot failure, insert system disk and press enter. how do you boot in save mode
Turn your computer off, turn it back on, as soon as you do that, start pressing F8 repeatedly until you get to a screen where you can access safe mode. If it's saying disk boot failure, you most likely have a dying/dead hard drive.
Jul 24, 2011 | HP Computers & Internet
I have a hp pavilion pc and it says boot disk failure please insert disk and press enter
Turn the computer off and then disconnect all the external devices like (printer,usb devices etc)connected to the computer along with the cable for the internet .Then disconnect the cable for power that would be right on top at the back panel of the computer tower and with the power cable disconencted press and hold the power button for atleast 30 seconds.Turn the computer on if it takes you to the desktop then it means that there is some external device that is causing the computer not to come up to the desktop so find which deveice has gone bad check it by conecting one device at a time.
Next thing that you can try is turn the computer off and then when you turn the computer on or as soon as you press the power button to turn the computer on start tapping the F8 key repeatedly until you get a black screen that says advance boot menu option .Then used the arrow keys on the keyboard and then hit enter,select the operating system and then when you get the log on screen select administrator .If it takes you to the desktop then you can try doing a restore by going to start?all programs ?accessories?system tools and then system restore ? select the date when you think that you r computer was working fine and then click on next next to exit from the wizard.Should fix the issue .
If the computer does not boot up to the desktop then without wasting time on any trobleshooting steps recovery needs to be done that takes the computer back to its original factory settings.To do this instead of the f8 key tap the f11 key till you get the screen that says system recovery ,click next until you get the screen that has advance option ?click on it ?select destructive recovery ?click next the recovery will start and the computer will be formated (whatever you have added after you bought the computer would be lost) ?If the recovery does not work this was then it needs to be done from the recovery disks and fot that you call call HP...
all the best
May 21, 2010 | Computers & Internet
Screen says disk boot failure, insert system disk and press enter
you have a hard drive failure. you need to replace hard drive.
Mar 29, 2010 | HP Pavilion Media Center a1330n - AMD...
My HP s123w Slimline Pavilion will not start up. Every time I turn it on, it goes to a black screen stating "DISC BOOT FAILURE, INSERT SYSTEM DISC AND PRESS ENTER" and I do not have the system disc. Any...
Take the floppy disk out of the drive... this sounds like the classic error when the boot order includes the floppy disk first, and a blank or data (not bootable) floppy diskette gets left in the drive.
There could be another type of drive set as bootable. CD's and DVD's don't normally do this - they usually cause a prompt "press any key to boot from CD..." or similar.
You could go in the computer setup and set the hard disc drive to be the 1st in the boot order and also solve this problem.
Otherwise could be your C: drive got damaged somehow. Virus or otherwise.
Jul 07, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Computers & Internet Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
