Question about Honda 25cc 4-cycle Mini Tiller
HAS GAS AND FIRE WILL NOT START - Honda 25cc 4-cycle Mini Tiller
  • 5 more comments
  • elamfern Mar 22, 2011
    THESE HAVE ALL BEEN TRIED AND IT WILL NOT START . I THUGHT MAYBE
    THE TIMEING BUT I DONT KNOW IF THERE IS A ADJUSTMENT . IF IT HAS GAS
    AND THE SPARKPLUG IS FIREING AND EVEN WITH A LITTLE GAS IN THE CYLINDER
    NO GO . ADVISE
    I HAVE TRIED ALL THE SUGGESTIONS LIKE REMOVE
    SPARKPLUG INSERT LITTLE GAS. PLUG HAS FIRE
    AND STILL NO START. IS THERE A TIMEING
    FUNCTION ON THIS TILLER ?
    FUNCTION ON THIS TILLER ? THE ENGINE HAS GOOD
    COMPRESSION.
    IT IS NOT A FUEL PROBLEM OR A SPARK PROBLEM
    OR A COMPRESSION PROBLEM . IS THERE A TIMEING
    FUNCTION ON THIS ENGINE? ADVISE
    ALL THESE THINGS HAVE BEEN TRIED WHAT ELSE?
    JERR,
    THANKS FOR YOUR INPUT. I DO NOT HAVE A MANUEL ON THIS ENGINE SO
    I WILL PROBABLY TAKE IT TO A SMALL ENGINE SHOP. I LIKE TO DO MY OWN WORK
    BUT THESE FOREIGN ENGINES BAFFLE ME. IS THERE ANY WAY I CAN TELL IF THE
    SHERE KEY IS SHEERED WITH OUT TAKEING IT APPART I'M OVER 70 AND MY EYES
    ARE DIM BUT I'M NOT-A-GONNA QUIT. THANKS AGAIN-------------JOHN
    ANSWER TO JEER. GOOD IMFO.-----JOHN
    Top Expert:
  • Honda Master
  • 81,400 Answers
If you spray starting fluid into the air cleaner does it start? If it really has gas and ignition spark it should start unless there is a mechanical problem with the engine or the engine is getting no air, so please verify the gas part again with the spray starting fluid, also recheck the spark by putting an insulated screwdriver blade into the spark plug terminal and holding it close to the engine metal, a good spark will jump a 3/8" gap no problem.
Posted on Mar 22, 2011
  • Marvin
    Marvin Mar 22, 2011
    Then the spark is to weak to fire the plug inside the cylinder due to the pressure it takes more energy to jump the gap, so just because it fires outside doesn't mean it does when the plug is installed, don't get burned by overlooking that. the other thing that causes this is the engine has a mechanical problem. I have been doing this 45 years and I do know what causes a no start. I see you have already given me the thumbs down without really allowing time to diagnose, that will end up only one way, you will not get it fixed anytime soon. Good Luck
    Brigadier General:
  • 3,513 Answers
Hi
Make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. Also if it has a primer bulb make sure the bulb is not cracked.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
    President:
  • 2,468 Answers
Remove the spark plug and try pouring a small amount of gasoline directly into the spark plug hole then reinstall the plug and see if it runs,then it can be a dirty carburator,then try removing the sediment bowl under the carb and see if theres dirt and/or water in there,if so dump out and clean out gas tank and refill with fresh gas,if it helps then you may also need to have carburator rebuilt
1995 4.3 engine will crink but not start , no fire no gas
When you put the ignition on do you see a check engine light on if not no power to the ecm check your fuses
Mar 22, 2015 | Cars & Trucks
Igniter Works, but Gas won't fire up on Sensor Dry, Will on Timed Dry
PLEASE do not use this dryer until it is fixed. it may be a saftey hazard. From the sounds of it. Your ignitor is only getting a signal every now and then. Now either is a coupler in there to tell the ignitor when to fire and when not to fire. It seems that it is going out only alloweing the dryer's ignition to come on only when a new cycle is started. That is where i would start... check with an appliance repair shop and find out if it will be something you can do your self or if it is something they have to do....
Now I do STRONGLEY recomend that you have a service technicion come on and service your dryer do to the fact that it is a GAS dryer. if something inside the dryer where to get pinched or broken it could cause a bigger problem....
so please take this advisment under consideration....
Thank you.
Aug 04, 2008 | Whirlpool GGX9868J Gas Dryer
Not starting
you need three things to start a car gas /fire /and timing check the timing first then see if you are getting fire to spark plugs then pull your fuel line at motor crank motor see if gas Is present no gas replace fuel pump no fire replace coil if timing has jump replace timing belt
Nov 18, 2013 | 2005 Toyota Corolla
1998 ford contour cranks but wont start
need more info is it getting fire getting gas remove he air filter and drop some gas down the carb if it starts then it is in the fuelsystem if not check your plugs that they aer fireing rember gas fire timeing and compreshion
Mar 05, 2013 | 1998 Ford Contour
Won't start can't even get it to fire got spark getting gas ,don't know.
Check the compression! It has to be around 120 and no less then 100 to fire off. If it is ok, Have your carb checked out. It should fire off with some spray.
Feb 10, 2013 | Poulan Garden
Leaking gas by carb
if u sre geting fire from the plug and u have gas i will say that its a good thing it dont start could led to fire and maybe alot of unnesry damge.but over all it should start hold to to the wild open it might be geting the wrong air to gas mix to run right .does it have alot of miles ,is the wires on right.if so then cheack ur time it may have jump or flat spot on cam .but if u have air gas and fire it has to start inless u r fireing on exs instead of intake.hope this helps u??
Sep 17, 2012 | 1976 Honda GL 1000 (K1)
328i won't start. Turns over but doesn't fire.
Sounds like your fuel pump has stopped working get it checked out.
Dec 27, 2009 | 2008 BMW 3 Series
Hard start and stalling with back fire when give it gas fast
sounds like you have spark plugs mixed up ever had them replaced
Nov 16, 2008 | 2002 Chrysler Sebring
Honda 25cc 4-cycle Mini Tiller Logo
150 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
