Question about Car Audio & Video
I have a mittsu endeavor 2005 and the stereo display appears "E Com" I think that it's blocked and in order to unblock I need that my stereo ak for the code but always appears "E Com", I don't know wich is the real problem, maybe you can help me. Thanks in advance four your help!!! Best Regards!!!
  • 1 more comment
  • gabriel_r737 Mar 22, 2011
    Thanks!!!
    I Have it, and the procedure too, so let try this afternoon disconnecting the battery and I hope the stereo ask for the code.
    I'll keep you updated.
    Regards,
  • gabriel_r737 Mar 23, 2011
    Thanks, I disconnect an few minutes later reconnect the battery and the E-com error still it appearing in the display, so I decide get out the front cover in order to assure the connections be correct, and try to get out the stereo to connect outside but I can't because there are something didn't let me get out it, so what you recommend me in order to fix it, can be an upgrade with the dealer or the RF amp integration Kit, but it works only with Endy 07 y 08 olnly.
    Thanks in advace for your help.
    Regards!!
    I have the code and the procedure, I did the you can said me but nothing change, still showing the "E Com" in display, what can I Try in order to the error "E Com" dissapear.
    Thanks in advance for your help!!
    Regards!!
  • 4,472 Answers
Do you have the radio code for your radio? If so you may want to try disconnecting and reconnecting the battery and inserting the code.
Thank you,
Lee
Posted on Mar 22, 2011
  • Lee A.
    Lee A. Mar 23, 2011
    Ok, there could be a connection issue between the deck and the amp. Could also be connection issue between the screen and the radio. If it is that big of an issue for your I would recommend taking it to a dealer as it's not an easy fix.
    Thank you,
    Lee
  • 17,970 Answers
Do you have the radio code? If so disconnect the battery and wait few minutes, then reconnect and enter the four number code.
If you donta have the "lock code" need to visit your dealer and showed that you are the owner with the VIN number (sometimes need to pay for this service).
Keep in touch.
  • ZJ Limited
    ZJ Limited Mar 22, 2011
    Additionally, other Mitsu owners is talking about this E-Com error and generally sounds like your amplifier has died. Also could be a loose connection
    but more then likely it's the amp. Warranty it if you can, otherwise it
    might be time to look for an upgrade.
    I think thats the post about getting rid of the error and the installation manual for it says it WILL correct the E-Com error (check this link): RF amp integration kit
    Good luck.
  • ZJ Limited
    ZJ Limited Mar 23, 2011
    Ask your dealer, this oppinion could give some clues to te next step (upgrade, RM kit, or replace it).
Is there a way to reset keyless entry for 04 endeavor?
Search Results
    2004 Mitsubishi Endeavor Key Fob Remote Programming ...
    blog.keylessentryremotefob.com/.../04/2004-mitsubishi-endeavor-key-fo...
    Apr 25, 2013 - 2004 Mitsubishi Endeavor Key Fob Remote Programming Instructions ... you might have visit us at Keylessentryremotefob.com You can also ...
    Mitsubishi - Free Keyless Remote Fob Entry programming .
    How To Replace Mitsubishi Endeavor Key Fob Battery 2004 ...
    ? 2:04
    www.youtube.com/watch?v=yeQRdre7O0Q
    Oct 31, 2014 - Uploaded by Keyless Entry Remote Inc
    ... will show you How To Replace Mitsubishi Endeavor Key Fob Battery 2004 2005 To Order This Remote ...
Nov 01, 2015 | Cars & Trucks
Tip
How to edit your blocked list on Facebook
Have you blocked someone by accident on Facebook, or blocked them on purpose but now want to remove the block? Follow these steps to access your list of blocked people on Facebook:
A. Log in to your account at Facebook.com.
B. Click Account in the upper right corner of the page.
C. From the drop down menu that appears, select Privacy Settings.
D. Scroll down to the bottom, and under Block Lists, click the "Edit your lists" link.
If you have ever blocked anyone on Facebook, you should see their names here under "Block users." Beneath that is the section where your blocked application invites will be displayed, if you have any.
To unblock a user, just find their name on the list and click "Unblock" next to the name. A confirmation box will appear to make sure you want to do that -- click the Confirm button. That person's name will be removed from the block list, and they can now contact you. If you decide you want to block them again, you'll have to wait 2 days in order to add them back onto your blocked list.
If you want to add a user to the blocked list, just type in either their name or email address (in the appropriate box) and click Block This User. If there is more than one person with that name, a list of possible choices will appear with each person's profile picture. Choose the one you want to block and click Block. You won't get a confirmation box here, so if you pick the wrong person, just unblock them and do it again to pick the right one.
on Jul 27, 2010 | Facebook Social Network
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
What would cause a mitsubishi endeavor to have oil in coolant reservoir
It was determined that your block has cracked and oil is leaking into coolant,the way you fix this is replace the engine.
Dec 23, 2012 | 2005 Mitsubishi Endeavor
How to unblock facebook
To unblock your account you will need to bring your concern to the Facebook Support Team. Send them e-mail at disabled@yahoo.com. Ask them to activate your account and ask them the reasons why they disabled your account. This is a one time re-activation so be very careful the next time you use your account in Facebook.
Some reasons why they block facebook account is because they found the account abusive and against their terms. If they taught your account is phished and spreading spams, most likely they will shut you off without warning..
Let me know if Facebook unblock your account. Comeback and give some ratings too. Thanks.
Jun 03, 2010 | Facebook Social Network
How do i remove the left rear panel on 2005 Endeavor?
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls
Oct 26, 2009 | 2005 Mitsubishi Endeavor
Just brought car and stereo is blocked how do i unblock it so i can try puttin a code and do you know the code for a ford fiesta o2 plate car stereo?
Remove the radio from the dashboard and quote the SERIAL NUMBER  found on the label of the radio casing
. It usually begins with M * * * * * *
Sep 08, 2009 | Pioneer Car Audio & Video
No sounds from stereo
sounds like that is the problem i think that you need a special harness go to this website: metraonline.com and look up your vehicle you should be able to find the harness at bestbuy or a car stereo shop not sure how much it could be. May be expensive.....
Mar 30, 2009 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
How do i fix the error e-com in my 2004 mitsubishi endeavor?
do you have the radio code??if so disconnect battery ,wait a few minutes then reconnect and enter the 4 number code and see what happens
Jan 15, 2009 | 2004 Mitsubishi Endeavor
Sharp LC37D44U. Display in top right corner keeps coming on. It cannot decide whether the audios is "mono" or "stereo."
I think you mean the channel/audio status display keeps coming on which normally indicates a poor reception (the channel beacon would come on when changing channels and then goes off) I think you should have your aerial system checked out.
SUPER8
Nov 22, 2008 | Televison & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
