Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 18.5 Briggs Model #42A707. I am continuously breaking the starter sprocket. The last sprocket was a Briggs sprocket
    Genius:
  • 1,015 Answers
If you are talking about the sprocket on the starter there is no cheap way to fix it that I know of. I've had the same problem on my 18 H.P. B&S motor on my craftsmen mower. The sprocket is a composit material and the flywheel is aluminum. I was replacing the sprocket about three times a year.I finally had a friend of mine who has a machine shop make me one out of aluminum and that fixed it.
I think this is just another case of planned obsolesence as a lot of people won't realize that the sprockket can be changed andwill buy a complete starter ***'y or take it to repair shop..
The only thing I can suggest is that you keep it tuned on a regular basis and not run the starter any longer then is absolutly needed.One other thing I have done for years on all my equipment is to run a small amount of Sea Foam in the gas at every fill.I use4-6 ounces and it really helps keep the motor clean and starting easier. Thankyou You can purchase sea foam at most auto parts stores and it can be used in the oil also. Good luck.
Posted on Mar 22, 2011
  • dcope131 Apr 21, 2011
    IF YOU WERE BREAKING THE GEAR 2 OR 3 TIMES A YEAR IT MIGHT HAVE BEEN KICKING BACK AND BREAKING THE GEAR OR WEARING IT OUT. BRIGGS IS BAD ABOUT THAT. VALVE ADJ. WOULD HELP THAT PROBLEM.
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Mtd yard machine mod#42A707 flywheel
Your probably will looking an used replacement on Ebay. Also you should use the complete engine info to look-up the correct flywheel but is the most common flywheel. Covers about 150 versions of the 42A707 series.
Flywheel 691976 for Briggs and Stratton Lawn Equipment eReplacement Parts
Feb 11, 2015 | Mtd Garden
I got a Briggs and Straton 16hp twin2 IC motor model number 42A707 and i dont know what kind of oil it takes. Can anyone tell me?
Takes a good grade of SAE 30 oil if on o snow blower in extreme cold a multi viscosity like SAE 10-30 would do..GOOD LUCK
Jun 30, 2012 | Briggs & Stratton Garden
Model 42a707 engine spitting gas out of carberator
Fuel needle leaking in the carb, remove the float bowl, check the float is moving freely, clean away any dirt, if no better replace the inlet needle.
May 06, 2012 | Yard Machines Garden
The plastic starter gear keeps breaking on my 24 hp. I have inspected the flywheel gear and it is in good condition. I get one or two starts and then the gear breaks. This last time I thought it was going...
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
May 13, 2011 | Briggs & Stratton Starter Scott's Equip...
I just want an owner's manual for briggs and stratton engine Model 42A707 Type 2238 E1
http://www.briggsandstratton.com/engines/support/operators-manuals.aspx?NTT=42A707-2238-E1
Should fix you right up.
Oct 05, 2010 | Garden
Model 42a707 Brigss. leaking at joint betwenn and
just remove the bolts from the bottom of the engine. several of them. slowly pull it apart. take care not to damage the seal. best idea is to replace it when u change the gasket. its pretty straight forward job
Apr 02, 2010 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
856 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
