Question about ViewSonic 17" LCD,8ms,1280x1024,280nits,600:1,170/155,VGA,BLACK Monitor
Sir I have Viewsoni VA1716W model LCD monitor But power LED not on I measure SMPS output voltage 12V and 5 Volt are available but power led not glow what to do please give me some tips.
  • 11,361 Answers
Since the power supply is OK, the next place to check will be the logic board, you need to find out if it is getting the 5vdc feeding it and also check for 3.3v, 1.8vdc, etc voltage regulators on the logic board. So far I cannot find free service manual to download for it.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
Testimonial: "good"
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
I have a 50 inch Samsung Smart TV UN50EH5300 that went dead...so I replaced the voltage supply board and it came on sound but no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 29, 2016 | Samsung UN50EH5300 - 50" 5 Series...
Hitachi 55in plasma TV, model 55HDS69. It will not power up from either the remote or the on/off switch on the side. The TV was used a lot, for more than 5 years. It shut off while running. The red...
Hi sir Jim!!!!
kindly check the 5 LED if there is lit lights to diagnose where the fault came from..You said the 5 led turn off for 1 -2 seconds it means no error but still won't turn on I think there sometime wrong on logic circuitry..
Try to read the voltages on highlighted words on picture of block diagram above such as vs,va,vcc,stby+5v,stby+3.3v,+5.5,+10.5 and +12v...
After that let me know the results to diagnose where the fault from..
Hope it helps...
chester..
Jan 19, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Made pop noises screen flashed considerable hum then no power no sound no nothing
This model no. is known for AC power adapter problem. Pop noises, flashes of the screen is an indication of out-of-regulation condition on its power supply. If there's no LED light lit, then high chance that the fault came from the AC power adapter.
This model no. used AC power adapter with a 12 Volts output feed to the unit. You have to confirm the 12V output using the multimeter set in DC measurement.
If the 12V output voltage is not present, then you have to replaced it with new one. This model no. is already discontinued, only substitution is available online which will work also for your unit. You may inquire/call Sears hotline no. (1-888-213-5824) to confirm and order the AC Adapter.
Please let me know if the Adapter is intact to assist you further.
Please rate only if you feel I've gave you the best answer. If you have any question, please let me know.
Have a nice day!
Jdvillanueva
Oct 30, 2011 | Proscan 19LA25Q 19 in. LCD Television
The power supply of my monitor doesnot work anymore. The blue power on led goes on and off. I have measured the supply voltage of 13,5 V and it goes on and off. With an external supply the monitor consumes...
http://s807.photobucket.com/albums/yy352/budm/Samsung%20205BW/
Attach a 12v bulb to the 12v output of the power supply, do not turn on the power switch because we just wan to lod the power supply with the bulb only, see if the lamp cycle on and off.
Check the DC voltage on the large cap (the one with 250~350vdc rating) on the AC primary side, it should have about 160vdc on it.
Use the hair dryer set to low and heat up the small cap by SMP IC on the heatsink as shown in picture DSCF0585 to see if the output 12vdc is on steady.
All the caps have flat tops and you replace them as a set?
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Dec 22, 2010 | Samsung SyncMaster 205BW LCD Monitor
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Mar 14, 2010 | LG 500LC Monitor
Daytek DT4660 - at ac on , led grn for 2-3 secs, one blink red, pause, 2 blinks red, pause , 3 blinks red, pause ,then rapid 5-6 red blinks followed by repeat of above. I've unplugged the 12 volt connector...
Hi
I work on Daytek 4660 models. I have seen the problem you are having and have solved it a couple of times by replacing all the capacitors in the power supply. If you use an oscilloscope to measure the voltages they may appear fine, however I have solved this problem by replacing all the capacitors in the 2ndary circuit of the power supply. It doesn't always work, but has worked in about half of the TVs that have come in with this problem. Also, just to make sure, if you remove the shielding from the board that drives the LCD panel make sure the little smt fuse is good. It's right on the 5V power line close to the ribbon connector from the main board.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Hi there my dell latitude d505 power adopter led goes out immediately at it plugged into the laptop power jack
You may want to make sure that it's pushed in all the way, as sometimes, those round plugs can fool you. Otherwise, make sure that the outlet is fully working.
Oct 22, 2009 | Dell Latitude D505 Notebook
No power
hi: first you will need open the monitor , them look for the power supplu board and with a multimeter measure the out put you shoud have 12v and 5v , if some of this voltage is missing your problem is the power supply board , you can try to fix it or buy a new board and remplace yours, now if you have the output voltage look for the power botton and take a measure in paralle with the switch you need to have there 5v if don't first check that the led is working fine because one i found the led bad and that was the problem , but that depend of the manufacturer construcction . if that led is fine your problem is a litter bit more complicate due that the problem will be on the logic board best solution buy a new logic board and remplace yours. best regards italocub
Jun 12, 2009 | Computers & Internet
ViewSonic 17" LCD,8ms,1280x1024,280nits,600:1,170/155,VGA,BLACK Monitor Logo
121 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
