Question about Mtd Products Yard Machines 158CC Tiller
I have a mtd yard machine front tine modle 135202 type 025801 5 hp starts runs for 1-2 min.thin stops
  • retired33 Mar 22, 2011
    this salution is not working
    President:
  • 2,468 Answers
Remove the sediment bowl off the bottom of the carburator and dump out any moisture,then replace it and see if you can keep it running with the choke partially on,if so then you have a lack of fuel due to a dirty carburator,if this doesnt help,the gasoline cap can get bad and go shut and vapor-lock loosen the cap and also try this
Posted on Mar 22, 2011
Wheres oil drain plug on huskie 6 hp front tine
Usually at the base of the engine, it will usually be a square nut, plug about 1/2" in size.
Mar 09, 2011 | Mtd Products Yard Machines 158CC Tiller
Belt broke on my 12 inch mtd yard machine front tine tiller model 21a-250m000 how do i replace it. thank you for your help!
part # 754-04123 v-belt 1-888-656-7278 for parts pull off 4 bolt on bottom red cover to frame replace belt put cover back on
Feb 27, 2011 | Mtd Products Yard Machines 158CC Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Need belt and bushing seals for (tiller)
try looking for tiller model 410 or 420
#215-410-019
the 135202 number is the b&s motor number
Apr 20, 2010 | Mtd Products Yard Machines 158CC Tiller
Need a manual for yard machine model# 135202
Hello:
A Breakdown should Assist youin Assembling the Tank and Carburetor. If the Engine Breakdown is Not at this Site, then Send me the OEM, Model and Type/Spec Numbers Off the Engine, Please. With these I can Locate the Correct Manuals and Better Assist you.
You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMan_10101_19502_-1 and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM (MTD) and Enter the Model Numbers. Then Double Click on the Model in the Results Area. Now you can Select the Section of the Unit you Wish to View.
You can Contact MTD at 1-800-269-6215 at during the following times and Request/Purchase a Manual: Monday-Friday 8am-5pm and Saturday 11am-3pm EST. (SEASONAL HOURS MAY VARY).
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Mtd Products Yard Machines 158CC Tiller
I have a 1996-1998 MTD yard machines,rear tine, dual wheel,chain drive,counterweight in front, walk behind tiller. It has the traction drve control on the left bar and the gear selection, side to side...
http://www.outdoordistributors.com/MTD/MTD_Main.html
click this link directly
Customer Service Phone Center Hours
are from 8:00 To 4:00 Mon. thru Fri.
(Central Time)
Click Here To See "US"
If You Are Ready To Order,
And Need Assistance, Please Call:
Toll Free 1-877-70-PARTS
(Orders Only Please)
If You Are Not Ordering
But Need
Information Please Call:
1-205-669-2500
More Contact Information
Click Here
one more good link for ordering parts
http://www.milacalawn.com/parts.asp
Apr 06, 2009 | Mtd Products Yard Machines 158CC Tiller
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Need manual for mtd 5 horse rear tine tiller model 135202 need to know how to change chain
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Feb 27, 2009 | Mtd Bronco Rear Tine Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
109 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
