Question about Dewalt Delta 17 950L 16.5" Twinlaser Crosshair Drill Press
How do I replace the rack on the column? The original one is bent, so I ordered a new rack and now want to install it. I can't figure out how to get the table support with the worm gear off of the column. I think that has to come off after removing the drill press head. Then I have to figure out how to install the new rack. Any ideas?
  • 7 more comments
  • johnbsnell Mar 22, 2011
    There don't seem to be any mounting screws. Before removing the head, I tried to crank the table support up, but it wouldn't go beyond the gear teeth on the rack. So, even if I remove the head, I don't see how to get the table support off the rack. Any ideas on that?
    1. There don't seem to be any mounting screws. Before removing the head, I tried to crank the table support up, but it wouldn't go beyond the gear teeth on the rack. So, even if I remove the head, I don't see how to get the table support off the rack. Any ideas on that?
      Did you get this?
    I have the table off and I didn't see any. I will go look again.
    No, I don't see any. there is just one large hex screw for the table tilt adjustment. Maybe I have to take the column to a delta service center. What do you think? I have the table off.
    We lost contact for a bit. I think I have the deck off, if that's what I call the table support. I can see everything clearly.
    I have the table off and can see the table support clearly. Maybe that's what you call the deck.
    I seem to be having trouble with replying. Where should I click to post a comment to you?
    have you gotten my recent posts? I have the table support, or deck as you say, off. No screws visible. I seem to have trouble getting your replies timely.
    are you still there? I haven't heard from you for a while. 11:49 central time.
    Genius:
  • 1,114 Answers
If there are not any mounting srews that hold it in place, as there are on some models, then you will have to re\move the rack you may have to remove the press head.
Posted on Mar 22, 2011
  • 3 more comments
  • Charles Huckeba
    Charles Huckeba Mar 22, 2011
    Check underneath the deck for the screws/mounting bolts.
  • Charles Huckeba
    If you are referring to the table that attaches to the press, it should tilt, maybe you should try tilting it and then see if you can access the bolts. The crank should be attached as well, because there are stoppers where the teeth on the shaft end.
  • Charles Huckeba
    You have the old deck off?
  • Charles Huckeba
    Had to get a bite to eat, sorry for the delay.
  • Charles Huckeba
    You should be able to remove the crank and then remove the part. If not then you may want to take it to a repair shop.
How to fix my steering rack on my 1983 mk1 golf gti
This is a shot in the dark, but its probably your lower steering column bearing, that will make everything wobble, and it happens to almost ALL mk1 vw's at some point. Just google "steering column fix" and you'll have it taken care of.
Your question is vague so that doesn't help. Doubt its the actual rack, as I have an original one in my rabbit with almost 400,000 miles. On top of that I had another rabbit that died around 400,000 with an original steering rack, and I am beating a dead horse by letting you know that my 83 gti has been punished since day 1, and guess what...stock steering rack.
Nov 29, 2012 | Volkswagen Golf Cars & Trucks
Replaced original 2001 Olds Intrigue Ignition lock cylinder-won't turn now
Pull it out and reinstall it. Chances are you did not get the new parts properly engaged with the opposite/complementary stops on the steering column.
Oct 06, 2017 | 2001 Oldsmobile Intrigue
My rack and pion is leaking , how do i replace
To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section. NOTE: The wheels of the vehicle must be straight ahead and the steering column in the LOCK position before disconnecting the steering column or intermediate shaft from the steering gear. Failure to do so will cause the SIR coil assembly (clock spring) to become uncentered, which may cause damage to the assembly.
  2. Lock the steering column by installing the J42640 into the underside of the steering column.
  3. Raise and support the vehicle.
  4. Remove the tires and wheels.
  5. Remove the power steering gear heat shield.
  6. Remove or disconnect the following: CAUTION
    Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control, which could result in personal injury.
    • Intermediate shaft lower pinch bolt and coupling from gear
    • Pressure and return pipes from the gear
    • Electrical connector, if equipped
      Stabilizer shaft links at lower control arms
    • Remove the left stabilizer shaft insulator.
    • Rotate the stabilizer shaft to access steering gear bolts.
    • The outer tie rod retaining nuts.
    • Using J24319-B separate the outer tie rods from the steering knuckles.
    • Rack and pinion attaching bolts
    • Rack and pinion assembly through the left wheel opening.
  7. Transfer the outer tie rods if replacing the power steering gear.
To Install:
  1. Install or connect the following:
    • Rack and pinion assembly through the left wheel opening and tighten the bolts to 70 ft. lbs. (95 Nm)
      Pressure and return lines to the steering gear and tighten the fittings to 22 ft. lbs. (30 Nm)
    • Heat shield and bolts. Tighten the bolts to 7 ft. Lbs. (10 N)
    • Install the left stabilizer shaft insulator.
  2. Install stabilizer shaft Links to lower control arms
  3. Intermediate shaft to the steering gear and tighten the pinch bolt to 35 ft. lbs. (47 Nm)
  4. Install the outer tie rods to the steering knuckles.
  5. Install the outer tie rods retaining nuts. torque the nuts to 22ft.lbs(30 Nm) plus an additional 180 degrees.
  6. Install the tires and wheels.
  7. Lower the vehicle.
  8. Remove the steering column anti rotation pin from the steering column.
  9. Fill and bleed the power steering system.
  10. Adjust the front toe.
Lock the steering column by installing the Steering Column Anti Rotation Pin tool J 42640 into the underside of the steering column--Aurora
Steering gear mounting bolts--Aurora
Power Rack & Pinion Steering Gear Heat Shield Removal & Installation To Remove:
  1. Raise and support the vehicle.
  2. Remove or disconnect the following:
    • The stabilizer shaft links.
    • Rotate the stabilizer shaft downward.
    • The electrical harness clip.
    • Power steering gear heat shield mounting bolts.
    • The heat shield.
To Install:
  1. Install the power steering gear heat shield.
  2. Install or connect the following:
    • The mounting bolts And torque to 89in.lbs.(10 Nm)
    • Rotate the stabilizer shaft into position.
  3. Lower the vehicle.
Figure of heat shield removed from above rack bolts with location shown
Feb 11, 2011 | 2001 Oldsmobile Aurora
How do you replace the steering rack on my 2001 Ford Windstar??
YOU HAVE TO SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS.MAKE SURE YOU HAVE VECHICLE PARKED ON LEVEL SOLID GROUND.ONCE VECHICLE RAISED.REMOVE FRONT WHEELS.REMOVE TIE RODS END COTTER PINS AND CASTLE NUTS.REMOVE TIE ROD ENDS FROM THE KNUCKLES.REMOVE FRONT STABILIZER BAR.POSITION THE DASH OPENING WEATHER SEAL FOR THE STEERING COLUMN OUT OF THE WAY.REMOVE OR DISCONNECT THE FOLLOWING.REMOVE PINCH BOLT RETAINING THE STEERING COLUMN INTERMEDIATE SHAFT COUPLING.REMOVE STEERING GEAR RETAINING NUTS BOLTS.REMOVE REAR SUBFRAME BOLTS.USE WIRE TO SUPPORT EXHAUST COMPONENTS UNLESS YOU ARE REMOVING THEM COMPLETELY.SUPPORT THE EXHAUST SYSTEM FLEX TUBE AND REMOVE THE FLEX TUBE TO DUAL CONVERTER Y PIPE ATTACHMENT.LOWER THE VECHICLE SLIGHTLY UNTIL THE REAR SUBFRAME SEPARATES FROM THE BODY APPROXIMATELY 4 INCHES.REMOVE THE HEAT SHIELD BAND AND FOLD THE HEAT SHIELD DOWN.ROTATE THE RACK AND PINION ASSEMBLY TO CLEAR THE BOLTS FROM THE FRONT SUBFRAME AND PULL TOWARD THE DRIVERS SIDE OF THE VECHICLE.PLACE A DRAIN PAN UNDER THE VECHICLE AND DISCONNECT THE POWER STEERING LINES.REMOVE THE RACK AND PINION ASSEMBLY THROUGH THE DRIVERS SIDE OF THE VECHICLE***** TO INSTALL ****** INSTALL NEW TEFLON O - RINGS ON THE POWER STEERING LINE FITTINGS. PLACE THE RACK AND PINION RETAINING BOLTS IN THE GEAR HOUSING.INSTALL RACK AND PINION ASSEMBLY THROUGH THE DRIVERS SIDE OF THE VECHICLE.INSTALL POWER STEERING LINES ON THE RACK AND PINION ASSEMBLY. INSTALL RACK AND PINION ASSEMBLY ON THE SUBFRAME.INSTALL ******** HEAT SHIELD.INSTALL TIE ROD ENDS TO THE KNUCKLES TIGHTEN THE CASTLE NUTS AND INSTALL THE COTTER PINS.INSTALL STABILIZER BAR.INSTALL RACK AND PINION ASSEMBLY RETAINING BOLTS.TORQUE THEM TO 85 - 99 FT LBS. RAISE VECHICLE UNTIL SUBFRAME CONTACTS THE BODY.INSTALL REAR SUBFRAME RETAINING BOLTS TORQUE THEM TO 83 - 112 FT LBS.INSTALL EXHAUST SYSTEM FLEX TUBE TO DUAL CONVERTER Y PIPE.INSTALL FRONT WHEELS.INSTALL A NEW PINCH BOLT IN THE STEERING COLUMN INTERMEDIATE SHAFT COUPLING ON THE RACK INPUT SHAFT TORQUE PINCH BOLT TO 25 - 33 FT LBS.POSITION THE STEERING COLUMN OPENING WEATHER SEAL OVER THE STEERING GEAR HOUSING.LOWER THE VECHICLE FILL THE POWER STEERING FLUID RESERVOIR. START THE VECHICLE AND CHECK FOR LEAKS. CHECK FOR PROPER WHEEL ALIGNMENT AND STEERING WHEEL POSITION.BLEED POWER STEERING SYSTEM.
Oct 14, 2010 | 2001 Ford Windstar
Tilt steering has loosened off. W/more than 4" play in the wheel, the ignition RACK HAS BENT, ALLOWING ACTUAtor to fall out of rack. How do I fix this problem
If it's too the point that parts have bent and fell out, it might be advisable to replace the entire column with a used one. However, if it seems salvagable, here is a write up on how to tighten the screws securing the tilt mechanism. Tilt column repair.
Aug 17, 2010 | 1987 Chevrolet Camaro
Need to remove ignition switch in my 1986 cutless to put new one in. how do I remove the old one.
NOTE This is an extremely difficult and lengthy procedure. You must remove the steering column from the vehicle and disassemble major portions of it. Because the column is collapsible in an accident, it is necessary that it be handled with care to avoid distortion of major parts. It must not be dropped, hammered on or even leaned on, or vitally important parts may deform. The procedure for replacing the ignition switch on tilt type columns is not included here because it involves substantial additional work and the use of several expensive special tools. Unless you are rather experienced, we recommend that the job be left to a competent professional mechanic.
  1. Disconnect the negative battery cable. Remove the clamp bolt from the steering coupling at the lower end of the steering column shaft (located near the steering box, under the hood).
  2. Disconnect the shift linkage from the shift tube lever at the lower end of the column.
  3. Remove the steering wheel with a puller, as described above.
  4. Remove the left sound insulator and lower column cover.
  5. Remove the trim cap or lower trim panel from the instrument panel, depending on equipment.
  6. Remove the steering column cover and toe-pan attaching screws. Remove the shift indicator needle from the shift bowl.
  7. Securely support the column in position and remove the two nuts attaching the column to the underside of the instrument panel.
  8. Lower the column carefully, being careful to retain any spacers that may have been used in order. Disconnect the wiring. Then, carefully remove the column from the inside of the vehicle.
  9. Begin disassembling the column, removing the lock plate, canceling cam, and turn signal switch. See the "Turn Signal" Removal & Installation procedure above.
  10. Remove the ignition lock and key warning switch as described below.
  11. Remove the spring and bolt assembly, and the associated thrust washer. Then, remove the rack preload spring, switch rack, and actuator assembly.
  12. Remove the upper shift lever spring. Then, remove the gear shift lever bowl.
  13. Remove the shift bowl shroud and bowl lower bearing.
  14. Unhook and remove the dimmer switch actuating rod. Remove the attaching nut and remove the dimmer switch.
  15. Remove the attaching screw and stud and remove the ignition switch, disassembling the actuating rod from the hole in the sliding actuator.
Replacing the ignition switch
To install:
  1. Move the ignition switch sliding actuator all the way to the left (ACC) position. Then, move it two detents (OFF-UNLOCK) position to the right.
  2. Then, position the actuating rod hole in the sliding actuator, and install the ignition switch, stud, and mounting screw.
  3. Install the dimmer switch with its attaching nut tightened only loosely. Then, depress the switch slightly until you can insert a 3/32 in. drill through the hole in the switch housing and slider. Force the switch upward to remove any lash and tighten the mounting screw with the switch in this position.
  4. Put the shifter in NEUTRAL and install the shift lever.
  5. Install the shift bowl shroud and bowl lower bearing.
  6. Install the rack preload spring, switch rack, and actuator assembly. Install the spring and bolt assembly, and the associated thrust washer.
  7. Install the ignition lock and key warning switch as described below.
  8. Reinstall the column into the vehicle. Make sure when assembling the lower and upper dash covers that they can slide on the column. If the bracket which mounts the column to the dash has been removed, install the bolts in this order:
    • Left rear
    • Left front
    • Right front
    • Right rear
Tighten the bolts just snug to avoid distorting the column.
  1. Install the switch connector to the ignition switch. Then, position the column in the body and support it there. Install the lockwashers and nuts for the coupling and tighten them. Then, loosely assemble the nuts fastening the mounting bracket for the column to the lower side of the instrument panel.
  2. Position the lower cover to the firewall and ensure that the cover is lined up by starting the left lower screw. Then, install and tighten the right lower screw. Then, tighten the left lower screw. Finally, install and tighten the two screws that fit into the top of the cover.
  3. Tighten first the screw for the left side of the cover clamp; then tighten the screw for the right side of the cover clamp. Finally, install and tighten the remaining cover screws.
  4. Finally, tighten the nuts fastening the column to the underside of the dash. Reinstall the bolt for the steering coupling clamp.
  5. Install the lock plate, canceling cam, and turn signal switch. See the "Turn Signal" Removal & Installation procedure in this section.
  6. Connect the wiring.
  7. Securely support the column in position and install the two nuts attaching the column to the underside of the instrument panel.
  8. Install the shift indicator needle from the shift bowl. Install the steering column cover and toe-pan attaching screws.
  9. Install the trim cap or lower trim panel to the instrument panel, depending on equipment.
  10. Install the left sound insulator and lower column cover.
  11. Install the steering wheel, as described above.
  12. Connect the shift linkage to the shift tube lever at the lower end of the column.
  13. Install the clamp bolt to the steering coupling at the lower end of the steering column shaft (located near the steering box, under the hood).
  14. Connect the negative battery cable and check all column operations for free movement and smooth operation.
Feb 15, 2010 | 1986 Oldsmobile Cutlass Supreme
Replacing a bent tie rod on my 2006 Subaru Legacy.
it depends if it is inner or outer tierod if it is inner i would get the bushings for it too
Jan 26, 2010 | 2006 Subaru Legacy
Just install new rack and pinion. return hose
is the unit for tha modle year ? is it a universal or oem replacement? the shop you got it at should have the matching lines, how ever if time is agance you try a hose building centre they may be able to provide an adaptor to match your hose
Oct 01, 2009 | 1993 Volvo 240
Power steering cuts out
I WORK FOR A CHEVROLET DEALER. THE THINGS THAT WE CHANGE MOST OFTEN IN THE HHR ARE THE RACK, INTERMEDIATE STEERING SHAFT, AND THE STEERING COLUMN.
IF THE STEERING IS CUTTING OUT IT'S USUALLY IN THE STEERING CONTROL MODULE. THERE IS USUALLY A CODE WHEN THE STEERING CUTS OUT. UNFORTUNATELY THE ONLY FIX IS REPLACING THE STEERING COLUMN.
MOST OF THE STEERING NOISES COME FROM THE RACK AND INTERMEDIATE SHAFT. BUT THE COLUMN WILL ALSO MAKE NOISE BUT IT WILL SOUND DIFFERENT.
Jul 21, 2009 | 2008 Chevrolet Hhr
Top rack slider
All I can think of is that the runners on the rack are not in the runner slide on the machine properly or there is an obstuction (EG:loose screw)in the runner on the machine side
Jan 22, 2009 | GE Adora GHDA656LSS Stainless Steel...
Dewalt Delta 17 950L 16.5" Twinlaser Crosshair Drill Press Logo
88 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
