Question about Porter Cable C2002 150 Psi 6 Gal Compressor
My air compressor won't build pressure. I have the valve turned counterclockwise, and all connections are tight. please help
  • 604 Answers
Make sure the valve you are talking about isn't the pressure control, if it is you need to turn it the other direction (clockwise) it the know is turned all the way open, you will get no pressure.
Posted on Mar 22, 2011
Cl6506016
Hi Larry
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Apr 30, 2013 | Air Tools & Compressors
My ingersoll rand compressor won't get up to set pressure
Hi bryon
Bud
Bud
Apr 05, 2013 | Air Tools & Compressors
I have a porter cable compressor, but the pump won't shut off, and the pressure won't build it
Hi
*Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
*Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
*Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
*Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
*Gaskets...Check to see if your gaskets have failed.
If correct then it will **** you hand against the intake.
*Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
*Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Nov 01, 2012 | Porter Cable Air Tools & Compressors
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
Takes long time to pump up, then have to shut it down, compressor acts like it wants to stop, but if I remove small line and let the air out of that side where the line connects, it will run fine but of...
Hi dmream55...
Sep 22, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
My coleman air compressor won't turn on and I am trying to ghet the top off to see what the problem is. A) How do I get the top off? and B) Why doesn't it turn on?
Hi
Sound like your pressure switch is faulty or maybe a faulty motor but:
Aug 28, 2011 | Coleman CL0551509H 15 Gallon Portable...
Craftman air compressor #919.166441 won't go above 50lbs. No leaks can be found. Holds air for days. Bought new regulator, same problem still exists
Hi
Here are a few things to check.
You may have already checked some of these.
Aug 25, 2011 | Craftsman Air Tools & Compressors
Compressor will only build up to 30psi,i have checked head gasket its ok reed valves seem ok (not broken)
there should be a pressure regulator on your compressor. sometimes the adjustment is covered by a plastic cap, remove the cap and use a flat screwdriver to turn the pressure regulating screw. clockwise for more pressure or counterclockwise to decrease the pressure. depending on the type of pressure regulator it should only take 2 to 4 complete turns to increase your pressure to 110-120 psi.
Dec 18, 2010 | Air Tools & Compressors
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Outlet pressure?
have you tried turning the pressure adjustment knob clockwise to increase regulated, not tank, pressure
Dec 12, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
278 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
