Question about Sony Playstation 3 (PS3) Console
Can't get heatsinks to sit properly on PS3 chips
I bought this PS3 off of somebody who said it worked. It was busted as soon as i plugged it in. I took it apart and noticed that after a bit of tweaking that it would display video and I could hear sound if the heatsinks were on OK enough. That lasted for about 15 seconds then the video locked up, sound died 5 seconds after. I think the problem has to do with me not being able to reseat the heatsink properly and it keeps having issues. I'm completely clueless and stressed about how to fix everything up on it. Any help would be great. Thank you.
    Problem Solver:
  • 11 Answers
USe a small amount of thermal adhesive.
Posted on Aug 03, 2008
Dark speck on processor
It may be the temperature problem. If the heatsink and the fan does not sit tight on processor the heat from the processor will not be dissipated properly and the heat rises up and the processor shuts off as soon as it starts working. So please see that the heat sink and the fan on the mother board sits tight. Also apply heatsink paste on the surface of the processor which comes in to contact with the heatsink. It comes filled in Syringe and retails around Rs.10-20 only. I think it will solve your shotdown problem.
May 10, 2013 | Intel Computers & Internet
New motherboard still no power
Remove the main battery and try again, next sub out the ram one at a time and test, I would sub out the power supply to be sure it is basically the only thing left.
May 07, 2012 | Dell XPS M1330 Notebook
We have a 2000 eclipse, a few weeks ago, somebody tried to steal it by busting up the steering colum. we just replaced the steering colum and the car doesn't want to start. does this car have a kill switch...
Yes, the car has an immobilizer, that only allows the car to start when the proper key (with the proper chip) is inserted into the ignition. Your new column prolbably has a different ignition cylinder (and thus the incorrect key) or is not capable of sending the signal to the ECU
Jan 29, 2011 | 2001 Mitsubishi Eclipse
I don't know technical terms but there is a 4screw x that holds the sink to the mother board just to the right of the x is a small square over a chip is the square super to have a pad on it or no pad and...
Let me see if I can decipher what you have stated killa_klowns, and offer a solution.
1) The Processor has a Heatsink on it, or a Heatsink/Fan combo. Depends on what the computer manufacturer designer wanted to implement.
{Some computers have a Heatsink/Fan combo sitting on the Processor.
Other computers just have a Heatsink sitting on the Processor, and air is provided by a Front computer case fan pushing air through a plastic cover onto the Heatsink}
Typical design for a Heatsink/Fan combo (Stock design. LGA 775 processor socket. Also, not a gamer type of rig),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5205492&CatId=493
Photos showing typical Intel Pentium 4 processors. Shows the top of the Processor's case that the Heatsink sits on,
http://www.cpu-world.com/CPUs/Pentium_4/Intel-Pentium%204%203.0%20GHz%20-%20RK80546PG0801M%20%28BX80546PG3000E%29.html
Where the headings state > Specifications - Pictures (5) - CPU ID (1) - Comments (15),
click on Pictures (5)
Thermal Paste should be used on the top of a Processor's case.
If there is a Thermal Pad, take it off, and fly it at the cat.
They're JUNK!
[ Always Thoroughly clean the top of a Processor's case, and the bottom of the Heatsink, before applying fresh new Thermal Paste. Same thing for every chipset.
> Observe Anti-Static Precautions A Processor is the most susceptible hardware component to Static shock.
Use a plastic scraper to clean the top of the Processor's case, and the bottom of the Heatsink.
I use an old credit card.
Then use Q-tips dipped in Isopropyl Alcohol (Rubbing alcohol) to clean the top of the Processor's case, and the bottom of the Heatsink.
May take several Q-tips dipped in alcohol. Usually a gooey mess.
CAUTION!!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a Well ventilated area with No sparks or flames present ]
The next chipset in line to use a Heatsink is a Northbridge chipset.
Termed Northbridge, for one, because in relation to how it is sitting on the motherboard, it is to the North of the motherboard.
On the motherboard the Northridge chip sits below the Processor.
The Northbridge chip may, or may Not have clips which hold the Heatsink on.
When no clips are used, > Thermal Glue is used to hold the Heatsink on.
{The motherboard chipset is the Northbridge chip, and the Southbridge chip.
Note* This info does Not apply to motherboards that support the Intel Core i3, i5, i7, or i9 processors}
The Super I/O chipset does Not use a heatsink.
Motherboard diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg }
Tell me what the motherboard manufacturer name, and Model Number is, and I can give you more detailed info about that motherboard.
Regards,
joecoolvette
Dec 04, 2010 | Sunon (16-02-006) Fan Kit
Why my computer shut down every 2 hours
right click on the desktop click on properties select the screen saver option in this option u can see the power option and selcet never option of turn off hard disk and standby options.
Nov 15, 2010 | Computers & Internet
How can I fix the flashing red light on my PS3
The flashing red light indicates the PS3 is overheating. This could be caused by: 1. a short circuit in the Power Supply 2. You may need a new fan or 3. the heatsinks may not be making proper contact with the motherboard chips.
If you don't want to deal with Sony we repair the red light error for $79 including shipping. GATpro PS3 Repair
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
TX-DS838 shows protect and then shuts down
yes , Im afraid you have a chip gone , If you open the unit up you'll see a alloy heatsink with 4 to 8 large chips screwed to it , These are the amp drivers , In between these chips you see a smaller one (that is the protect chip),You see when things get a little hot this chip is designed to break sooner that the more expensive main amp chips , In the past ive unsoldered these and still found the amp driver bust too ,dont worry though , maplins or even farnell(cpc) on the web will supply these for less than a tenner..If you wanna test my fix then just unsolder the littlest chip on the main heatsink and it should start to work again but with NO protection(unplug it first before taking it to bits)
Jun 06, 2009 | Onkyo TX-DS838 Receiver
Overheating although cooling fan & heatsink are ok
u r saying that the laptop is overheating. I think it is from cpu overheating right. just to make sure that it is cpu overheating, just go to the following link and download the software around 1mb which displays each and every component heating levels.
from that you can find out the exact component.
http://www.cpuid.com/software.php
if cpu is heating then just replace the thermal interface material and the problem will be gone.
if the cpu thermal interface material is too old then this type of problems arises
Apr 19, 2009 | Computers & Internet
FAN COMING ON WAY TOO EARLY
It is overheating. the chip has an internal temperature sensor.
I bet if you put your hand ontop of it when it does this it is blowing out fairly hot air. Mine is doing it because I took it apart to fix the fan and didnt use enough heatsink paste. if you have lots of ventilation and it cant be overheating then try taking it apart and redoing the heatsinks.
Sep 28, 2008 | Sony Playstation 3 (PS3) Console
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Mar 24, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
