Question about KitchenAid Food Mixers
Model#k45ssdwh mixer,drip seal leaking oil arround mixing head and dripping into mixing area
SOURCE: hobart h600 60qt mixer leak oil
call me. 626-579-3580. Ill fix it.
Posted on Mar 26, 2008
hslincoln
  • 235 Answers
SOURCE: oil is leaking from the main body of the mixer in
Hi CERILEY, Merry Christmas & Happy New Year! Sorry to hear about your mixer’s leaking grease (oil) from your planetary/agitator shaft (‘moving mixing part’). It can be a distressing sight, but there’s no need to panic.
If the amount of oil found leaking is small and if your mixer otherwise works normally with the missing oil you really don’t need to take your mixer apart to ‘fix’ it. The good news, though, is that you can take the mixer apart and 'fix' it, if you feel it is necessary.
The internal gears are factory packed with enough grease to last a 'lifetime', whatever that means? Depending on the age of your mixer, where it’s been stored and how heavily it’s been used; these factors all will eventually cause the grease’s base oil to separate from its hardening additives, with the resultant oil seeping from openings beyond the gasket and “O”-ring and generally follow the path of least resistance down to the lowest point, i.e., the agitator shaft. Gravity can be very insidious.
What should you do? For starts just clean your agitator shaft and pedestal with a sponge and hot, soapy water (DO NOT immerse your mixer in a sink of hot soapy water, though!).
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty, which it is. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM90P, and select one of the files KSM90PSWH0.pdf (354.08 KB)listed under Parts List (16) (check to see it this matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. Nos. 18 and 32. For starters you may want to order these replacement parts: Transmission Case Gasket (Part # 4162324) and “O”-Ring (Part # 67500-00), along with gear grease. Look for a ‘food-grade’ grease (Lithium grease is white, although the original grease is vanilla extract colored).
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Also, while your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, repair, re-grease and reassemble your mixer.
Finally, if you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! – hslincoln
Posted on Dec 28, 2009
SOURCE: My classic k45ss leaks oil which drips from the
Firstly I would take the head apart to find out what has failed. The oil you see should be a thick grease. Normally it is thick enough not to leak in this way. Has it been repaired and the wrong grease used? If it is making a funny noise it could be that one of the gears has failed. Most parts are easily available. Have a look at the parts list at:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Posted on Jan 24, 2010
SOURCE: Kenwood Mixer A901 dripping gearbox oil through
the seal is in the middle of the bearing take gearbox to piece (not easy) and remove with bent sharp needle
Posted on Feb 18, 2010
  • 119 Answers
SOURCE: I have Hobart Mixer Model
The transmission has to be disassembled for this repair. I believe your best option is to contact your local Hobart office and have them do it.
Posted on Sep 13, 2011
Why am i seeing grease drip from the head unit?
One of two things should cause this.
First, is the mixer really old, or has it operated in an extreme high heat area ( for example, next to a oven or stove)?
Grease is a mixture of oil and soap, and those two can separate from heat or old age, then the oil can leak.
Second, a seal or a bushing may have worn out, allowing the leak.
God bless your efforts.
Mar 21, 2016 | Globe SP40P - Commercial Mixer - 40 Quart...
Kitchenaid leaking oil
Remove the chrome drip ring that covers the outer planetary, clean it out, wipe as much oil away as possible, put the drip ring back on and carry on using it. Eventually you will need to completely dismantle the gearbox and clean out & change the grease. It's not the sort of job to look forward to. The old grease slowly breaks down over time and the oil is separating out from the grease solids. It is special food grade grease so completely harmless.
Feb 08, 2014 | KitchenAid 32685 Mixer
Kitchenaid mixer leaking oil from head.how to fix it.
It's not oil, it's grease. Here is a very detailed article on how to add grease to the mixer. After you have added some new grease and tightened the screws it will stop leaking. The temporary fix is to simply remove the chrome ring as is done in the picture on the attached link, clean out the oil and stick it back on till it fills up again. It is called a drip ring for the reason that it catches the oil component of the grease which drips from the gasket when the screws loosen:
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
Jan 09, 2011 | KitchenAid K45SS Classic Stand Mixer
MY MIXER IS LEAKING GREASE OR OIL FROM THE HEAD THAT TURNS THE MIXER. WHAT IS THE FIX? IS THIS A FIXABLE PROBLEM? CAN I FIX THIS MYSELF?
I'm assuming yours is an older model with the tilt-head feature.
Apr 13, 2010 | KitchenAid 32685 Mixer
My classic k45ss leaks oil which drips from the verticle shaft, and my wife says it is making a "funny noise". Maybe it is low on oil, but I turned it on its side to find the model number, and it leaked...
Jan 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Leaking Dark Oil
Sounds like a combination of two issues.
1. In all likelyhood, the viscosity of the lubricant in the main transmission of your mixer has broken down and is now oil rather than the grease it once was.
2. The seal on the main transmission shaft is worn and the "oil" is leaking past it, resulting in drops of oil forming on the bolt head at the bottom of your planetary and dripping into your bowl.
Draining and replacing the lube and seal is a rather involved repair. To do it properly, complete transmission disassembly is required.
If it was my pizza business and there's just a drop of oil here and there ( 1-3 drops in the bottom of bowl in the morning ) I'd let it ride, keep wiping the oil away prior to mixing a batch and budget (apprx $500-$600 ) for a proper repair as it becomes worse over time. Unfortunately, it won't get better.
I'll add.
It's been my experience that D300's and pizza dough don't play well together. Be certain to calculate the weight of all your ingredients and then consult the capacity chart found here. http://www.kroslakbakeryequipment.com/pdfz/HOBD300.pdf
Stay within the guidelines and you should be fine...however your batches will be rather small.
Hope this is of some use.
Oct 17, 2009 | Hobart Food Mixers
Oil leak from planetary
The transmission center shaft seal/chimney is bad.You need to tear the transmission down in order to repair,let me know.
Apr 29, 2009 | Hobart H600 Stand Mixer
Oil leakage
Is the oil leaking down the beater shaft?Remove the silver drip cup,3 screw's one in the midlle,one on the right and one on the left.Once you drop the drip cup if it's filled with oil then you may need the seal's in the transmission replaced.
Mar 14, 2009 | Hobart A200 Stand Mixer
Hobart h600 60qt mixer leak oil
Mar 25, 2008 | Hobart HL600 Legacy Stand Mixer
Food Mixers Logo
49 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
