Question about Epson Stylus NX100 InkJet Printer
When I turn my epson stylus nx100 on the power button won't stop flashing and the cartiridge holder doesn't move.
    Sergeant:
    Champion:
  • 220 Answers
Here are the error codes for your Epson model.
Check them and define the problem according to the situation you got.
Posted on Mar 22, 2011
When I try to change black cartridge in Epson NX100 the carriage will NOT STOP - flips back and forth. How do I get it to stop so I can remove the cartridge - Black is only one out.
1. Turn on your Epson Stylus NX100 Series printer. Your printer should be plugged in and connected to your computer.
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to allow you to change cartridges.
3. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
4. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
5. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer
NOTE: Beware that you must have all ink cartridges full because Epson uses color even when only printing black and white (lots of comments here about that scam!!)
Sep 05, 2011 | Epson Stylus NX105 All-In-One Printer
Need all steps in changing black ink cartridge
Hi Good day!!! Here are the steps how to replace cartridges
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to show you which cartridge is low and needs to be replaced.
3. Press the stop button once more. If other cartridges need to be replaced, the printer head will indicate which ones by stopping on those cartridges each time you press stop. If no other cartridges need to be replaced, the print head will move replacement position on the right.
4. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
5. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
6. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer.
Don't forget to vote thanks!!!!
Nov 02, 2010 | Epson Stylus NX105 All-In-One Printer
I have an epson stylus NX100 and i just put brand new black ink in it recently i printed two pages max i went back to use it and it says that my black ink has expanded and i have to buy a new one? what...
***hi there,ill be willing to help you on that. ****
try to reseat the cartridges first to charge it again, reseat means Remove and reInstall the Cartridges. after doing that and still the same issue, and you have an extra set, try to load another brand new ink,just to isolate if it is the ink thats causing the problem, if the same issue persist, its not the ink that you bought, its the printer already, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
If the ink light is flashing, a cartridge is low on ink; replacement is recommended.
2. Open the scanner and prop it up with its support
3. Press the nx100_tx100_ug.1.93.5.jpg Stop button. The print head moves to the nx100_tx100_ug.1.93.6.jpg position to indicate which cartridge is low or expended.
4. Press the nx100_tx100_ug.1.93.8.jpg Stop button again. If another cartridge is low or expended, it moves to the nx100_tx100_ug.1.93.9.jpg position. Press the nx100_tx100_ug.1.93.10.jpg Stop button again to see if more cartridges are expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right. 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
7Remove the cartridge from the package
8. Remove the yellow tape from the bottom of the cartridge.
9. reInsert the new cartridge into the holder and push it down until it clicks into place. 10. Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner.. 11. Press the nx100_tx100_ug.1.93.18.jpg Stop button to begin charging the ink. This takes about 1 1/2 minutes. When the nx100_tx100_ug.1.93.19.jpg On light stops flashing and remains on, ink charging is finished. Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
Jan 21, 2010 | Epson Stylus NX100 InkJet Printer
Trying to replace the black inck cartridge and cannot get the cartridge holder to stop at a position for me to pull out the old cartridge and insert the new cartridg. I've have an Epson Stylus NX1000...
Found this on the Web for Your Printer. You can download the Manual from Epson.
If you find this helpful, pls rate me.
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Checking the Print Head Nozzles
If your printouts are faint or have gaps in them, some of the nozzles in the print
head may be clogged or ink may be running low in one or more of the ink
cartridges. Follow the steps below to check the print head nozzles.
1. Load letter-size paper in the sheet feeder.
2. Turn off the NX100 Series.
3. Hold down the y Stop button as you press the P On button to turn the
NX100 Series back on. Hold down both buttons until the P On light begins
to flash, then release the buttons.
Cleaning the Print Head 21
4. Check the nozzle check pattern that prints to see if there are gaps in the lines.
5. If there are no gaps, the print head is clean. If there are gaps or the pattern is
faint, clean the print head as described in the next section.
If print quality has declined and the nozzle check pattern indicates clogged
nozzles, you can clean the print head. Print head cleaning uses ink, so clean it only
if necessary.
Note:
You cannot clean the print head if an ink cartridge is expended, and you may not be able
to clean it when a cartridge is low. You must replace the cartridge first (see page 23).
1. Make sure the NX100 Series is on and the B ink light is off.
2. Hold down the y Stop button for three seconds to start the cleaning cycle,
which lasts around one minute.
Caution:
Never turn off the NX100 Series during head cleaning or you may damage it.
3. When the P On light stops flashing, run a nozzle check (as described on
page 20) to verify that the print head is clean.
4. If there are still gaps or lines, or the test patterns are faint, run another
cleaning cycle and check the nozzles again.
Note:
If you don’t see any improvement after cleaning the print head two times, turn off your
NX100 Series and wait at least six hours to let any dried ink soften. Then try cleaning
the print head again. If quality does not improve, one of the ink cartridges may need to
be replaced. If that doesn’t help, contact Epson as described on page 31.
If you do not use your NX100 Series often, it is a good idea to print a few pages at least
once a month to maintain good print quality.
Good Luck and Please rate me.
Jan 13, 2010 | Epson Office Equipment & Supplies
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Computer says black ink is low. Ink light is flashing on Epson Stylus NX100. When I hit stop button to begin replacement it wont move cartridge
2. Open the scanner and prop it up with its support.
3. Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
4. Press the Stop button again.
If another cartridge is low or expended, it moves to the position. Press the Stop button again to see if more cartridges are expended.
6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
9. Insert the new cartridge into the holder and push it down until it clicks into place
11. Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
When the On light stops flashing and remains on, ink charging is finished.
Caution:
If the ink light flashes, press the Stop button and press down all the cartridges securely.
Jul 13, 2009 | Epson Stylus NX100 InkJet Printer
I have a NX100. Christmas present. (Ho Ho Ho) The Power button, paper button, and ink button are all flashing. I have put paper in. I have held the stop button for as long as 6 seconds, but the ink...
if all lights are flashing, there is a great possibility that the printer is having an internal error. try the ff. steps, turn the printer off, unplug it from the power outlet, lift the whole scanner, check for any obtruction inside the printer, take it out, if none, thats good. plug it to the power source again, trun it on, if same issue persists, that means, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
Dec 25, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Cannot get LCD screen to show Replace Ink message
try this
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from it's package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus RX500 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus RX500 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady. At this point press COPY to move back to COPY mode.
Caution: Never turn off the EPSON Stylus RX500 while the On light is flashing, unless the Stylus RX500 hasn't moved or made noise for more than 5 minutes.
May 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
1. Make sure the EPSON Stylus CX5400 is turned on and not printing.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus NX100 InkJet Printer Logo
223 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
