Question about Tools & Hardware - Others
Model #315.11650 how to change the sandpaper?
  • 604 Answers
You don't list the make of your sander, the model number doesn't tell my what type of sander this is. you can contact me and let me know the brand and then perhaps I can help you.
Posted on Mar 22, 2011
What type of sandpaper do I use on a dewalt dw421?
this sander appears to use the hook and loop system, you can download an instruction manual by going to dewaltservicenet.com and typing in your model number.
Jan 04, 2012 | Dewalt DW421 5'' orbital sander
Could you please tell me what sandpaper goes on the Mouse sander/polisher model # MS500
ok this easy go to the hardware store and ask for the sandpaper to fit your sander, black & decker make sandpaper specifically for that sander. now depending what job you want to do will determin what grade you want sand paper works like this the higher the number on the paper the finer it is so for example 80 is very coarse you would use that for eg stripping thick paint on a door but 2000 is very fine and is used for eg sanding varnish between coats. ok hope that helps let me know how you go.
Mar 11, 2011 | Black & Decker Mouse Sander/Polisher
Changed batteries-lights will not come on? simple comfort 2210 unit
This problem is common to battery contact,just take out battery,then take a sandpaper and clean the battery contact lead with a sandpaper both sides if problem persist,then you better to open the unit and look for power supply section then re solder all parts there.
Hope it may helps:
Jan 24, 2011 | Heating & Cooling
How do you change paper on a black & decker finishing sander 7404-04
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Aug 14, 2010 | Tools & Hardware - Others
Change sandpaper head on dremel motor tool
if your talking about the barrel sander there is a screw on top that you loosen and the barrel will slide off put the new one on tighten screw and your good to go
Jan 09, 2010 | Hand Tools
How do I change the sandpaper in my Black & Decker Sander 7448? I lifted the two levers and the sandpaper came out but now I cannot get them to close tightly around the replacement sandpaper.
there are many types of sizes for this sander check you have the right size first,,, after that check that the return springs in the belt tenshioner are poping out fully
Nov 15, 2009 | Tools & Hardware - Others
Sandpaper sliding off
there isnt enough tension on the belt, hence the side to side movement. keep tightening the spring until it stops
Jul 22, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
260 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
