Question about Ricoh Aficio CL3000 Laser Printer
Sc-486 on the Ricoh Aficio CL3000 printer - Ricoh Aficio CL3000 Laser Printer
  • 903 Answers
Sc486 is a problem with either the engine control board or the drive unit, or the connection between them. One or the other will probably have to be replaced, depending on exactly what's causing the problem.
Posted on Mar 22, 2011
Testimonial: "Thank you I did not have the service manual for that printer. "
Drivers for aficio cl 3000
Yes it's compatible with windows 7.
Click here
You can download the driver from above link.
Let me know if you need further assistance.
Thanks for using FixYa.
Aug 15, 2011 | Ricoh Aficio CL3000 Laser Printer
How do you reset a ricoh aficio cl3000 printer?
If you mean JOB RESET then there is a button near the printer display. If you want to reset some PM call (for PCU or maintenance kit) you must enter the service mode(hold the two UP and DOWN arrows together for about 6 sec and then released it and press ENTER immediately). You will enter service mode . Choose 2. Engine and press ENTER. theh search for 7. DATA LOG and press enter. Then search for SP7804 PM_COUNT_CLEAR and then press enter. There you can reset what you want. Then press escape to main menu and exit
good luck
pifonski
Feb 21, 2011 | Ricoh Aficio CL3000 Laser Printer
My RICOH AFICIO CL3000 give me an error message SC441, what to do ?
Did you just replace your color PCUs (photoconductor units)? If so, one of the new units may be defective. Try reinstalling the old units to see if the problem goes away (after resetting the machine). If it does, you can replace the PCUs one by one to see which one is bad.
If you still get the sc441 even with the old PCUs (or if you don't have them anymore) install a set of new PCUs and that should fix the problem. On the off chance the problem doesn't go away even with new PCUs, contact your local service company because you may have a bad circuit board, motor, or gear.
Nov 15, 2010 | Ricoh Aficio CL3000 Laser Printer
Has bee my default printer until now. Connection to router is fine, will not print - only gives error message. none of the buttons on the control panel work. online light is out. is this a big fix or...
go to the control panel, select printers and double check if the Ricoh Aficio CL3000 Laser Printer was selected as a default printer. you can check it by right clicking the printer name and choose set as default.
Sep 13, 2010 | Ricoh Aficio CL3000 Laser Printer
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Error SC 411 appears
SC411: Separation bias error
-Definition- [B] A separation bias leak signal is detected. - Possible causes - · High voltage supply board defective · Poor connection of the PCU · Discharge brush defective You need the service manual or have a technician fix it. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 15, 2009 | Ricoh (R) Aficio CL3000 Color Laser...
Getting error code sc 486
Sometimes it seems to be that the sensor for the waste toner is picking up that it is full. If you clear the are that the the laser reads, many times this error code goes away. Also,, just replacing the waste toner cartridge fixes it.
Apr 03, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh c3000 replace fuser error
try to unplug it from the wall and plug it back in and let me know if this works
Feb 02, 2009 | Ricoh Aficio CL3000 Laser Printer
Ricoh Aficio CL3000 Laser Printer Logo
546 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
