Question about Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN
My Minka Aire fan won't reverse. It's a wall switch & when reverse is pressed while on low speed it makes a noise slows up speeds up & then slows again , but still no reverse action. Pls. assist Byrnesp@bellsouth.net
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
SOURCE: light dims up and down repeatedly
PROBABLY THE WALL CONTROL SWITCH IS BAD.
ASK YOUR LOCAL DEALER TO BORROW ONE HE HAS IN STOCK. AND OR BUY BOTH THE RECEIVER AND THE SENDER. MY WALL SWITCH MALFUNCTIONED.
Posted on Feb 18, 2009
SOURCE: Minka Aire Fan will not reverse.
My fan is a concept II and it had the same behavior. I called Minka Aire support about this - they said it was either the reverse module or the receiver. They sent me both no charge! I replaced them and now my fan reverses. i am not an electrician, but the replacement was fairly easy. Just made sure to disconnect 1 wire at a time, connect it to the new wire, etc until I was done. Minka Aire support said they would walk me through it on the phone but I didn't need them to.
Posted on Dec 10, 2012
SOURCE: Minka aire ceiling fan
My Minka Aire remote is not working. When I use the remote nothing happens. When I turn on the switch using light switch nothing happens. I had it installed two years ago. Battery never replaced.
Posted on Jul 17, 2009
  • 10865 Answers
SOURCE: Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Posted on Sep 07, 2009
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
I bought and had installed a Minka Aire Ultra Max ceiling fan about 4 months ago. It works great with the remote and until about a month ago I had no problems with it. Now, it has developed a clicking...
A lot of fans have a clicking noise if they have a chain hanging down and the balance is not perfect and the fan wiggles a little. It will only happen at certain speeds that are "resonant" where the swinging can build up. The pull chain then makes the noise as it hit the case.
Mar 09, 2010 | Minka Aire (Ceiling Fan)
Sep 30, 2009 | Minka -Aire Brushed Nickel Remote Control...
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN Logo
2,344 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Marvin
Marvin
Are you a Minka Dryer Expert? Answer questions, earn points and help others
